2006 JD 1600 Turbo WAM
   / 2006 JD 1600 Turbo WAM
If it was the turbo charger, chances are the engine would not run because when a turbo lets go, the cold side of the turbo comes apart and the engine eats the blade parts and in turn eats the engine too or at least the top end. Turbo's are not forever and that is why it's important to remove the outlet side of the piping and check for freeplay in the turbine rotor radially and back and forth occasionally and determine if it spins easily. If I had one go, I'd much prefer it to be a seizing bearing on the hot side which is a ceramic bearing that the other alternative. When I worked at the Western Star dealership I retired from, every grenaded turbo resulted in at least a top end rebuild and / or a new head depending on the amount of damage and they all came in on a wrecker too. You have other issues.
Don't believe I mentioned anything about the turbos as the engine operates as it should.
Did you check the differential for that blade? You may have busted a gear. Pull the top cover off and inspect the gear set.
Wouldn't that cause it to not work all together? It works when the blades are engaged outside of grass and has full power, when I creep into the grass it starts to bog down and wants to proceed to kill the engine unless I turn the blades off. All blades spin freely by hand. Seems to get worse the longer the motor runs as the fluid is heating up and slipping by the o-rings?
   / 2006 JD 1600 Turbo WAM #13
PTO to me means engaging the blades, but yes it is all hydraulic driven. I'm thinking it the hydraulic motor as well, which I believe is located under the seat?
I do not know your machine very well but from the pictures it looks like this is the system:
1, you have the diesel engine which is behind the operators seat.
2, there is a hydraulic pump which is connected to the engine by a shaft and also likely behind the operators seat.
3, there are hydraulic lines coming from the pump to hydraulic motors, one on each deck.
4, the hydraulic motors on each deck drive the blades and it seems like there are also some blades driven off the motors with belts.
So the hypothesis goes that there might be some damage that was done to either one of the spindles that the blades are attached to or possibly the hydraulic motor itself when you got that branch caught in the mower deck.
Look for excessive play or binding in the bearings at the blades. Check condition of hydraulic fluid, level, color, metal shavings. Check to see how hot the hydraulic motor gets compared to the others when in operation. This is a start at trying to figure out what might be going on.
Hope this helps!
   / 2006 JD 1600 Turbo WAM #14
I think the hydraulic motor spins the blades. Definitely not under your seat. I think I would start over. Make sure all blades are free. Then start isolating and troubleshooting if necessary
   / 2006 JD 1600 Turbo WAM #15
These are very complex machines.
Did you get your fixed?
I recently picked up a 2011 series 2
I’ll have been trying to get aquatinted with my new machine.
I may have something similar happening. Tell me if it the same or not.
While mowing the sound and blade speed goes from high to very low. Ive narrowed it down to the blade speed changing with very slightly taller grass. Im talking like 6” tall grass. When i stop moving or go over shorter grass the blade speed picks back up.
It does not bog the engine the engine doesn't vary. Only the blades slowdown.
I bought a $20 photo tachometer and checked blade speed 2400 rpm when working correctly down to about 1000 when “bogged down”.
The uses like 3 separate hyd pumps. Transport, mow and steering.
It has its own (mow)hydrostatic pump just for the blades.
It uses a small hyd cyl to actuated the hydrastic mow pump. (Thats how you adjust blades speed) i verified by watching this cyl while mowing that it doesn't move when the speeds change.
If i lift 1 deck i don't have an issue.
Im wondering if my pump ($4k) might be worn. Not sure what else it could be. I haven't checked the hyd tank strainer cause its a big job but i think that would effect flow not pressure. And this seems like a pressure issue.
The small amount of grass that bogs down the blades blows me away.
Is this at all the same as your issue?
A manual is needed.
Still looking for the fix before I start tearing into it. Mine since day one has had a small issue with thick/tall grass but still works and just had to slow down at times. My first thought was the mower pump under the seat (which is most expensive and can be rebuilt; $3k for all three pumps if I remove them and reinstall them), but I think I'm having flow issues as it'll run fine for 2-3 seconds, then load up and want to stall the engine.
   / 2006 JD 1600 Turbo WAM #17
Have you checked the hyd suction strainer. You gotta drain The 15 gallons of hyd oil and it looks messy but that’s a free job unless you replace the hyd oil.
I have not and I have another hydraulic filter coming. Won't I have to drain the fluid to change the filter or no? Is the suction strainer in the tank or no? I was planning on straining and reusing the same fluid as it only has 50 hours on it from a blown hose last year.
   / 2006 JD 1600 Turbo WAM #19
The filter you can change without draining but be prepared and have what you need a a good pan under it. You will loose half gallon or so. I did it yesterday.
The strainer is in the bottom of the tank. Right hand side. You will see the drain pointing out the right side. The strainer is below that level unfortunately. If you take off the electrical panel door there is a large 1 1/2” hose that runs from the front of the tank then turns 90. And goes to the pump. The strainer is in the tank where the hose connects. Looks like a real peach of a job. Bound to get hyd oil everywhere. It’s a cleanable strainer so no need to buy one for $150.
I’m so reluctant because I don’t think it’s going to change my issue.
I’d like to know if this machine can normally cut with a mulch kit 6” grass it’s not even thick grass and I have new gator blades.
Thanks for the info. I run gator blades and cut at 2.75" as it's my own personal 15 acre yard. It doesn't like the thick grass on the overflow from the pond but it makes it through, then one little 2" stick stopped the entire world.
2269 (A58376)
2269 (A58376)
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
John Deere 6110M (A53317)
John Deere 6110M...
2010 CHEVY SILVERADO 3500 HD PICK UP TRUCK (A59575)
2010 CHEVY...
Hot Pressure Washing Equipment Set (A56857)
Hot Pressure...
2831 (A58376)
2831 (A58376)
