2005 TN 70A Sticky Clutch Pedal
   / 2005 TN 70A Sticky Clutch Pedal #1
RW444
New Holland T70
Tractor has about 2400 hrs and transmission is a mechanical shift 12 speed
The pedal started sticking not wanting to engage smoothly which causes jerky engagement, with the tractor running the pedal always comes out but when not running you can engage clutch, release and the pedal will stop about half way out.
I thought the linkage might be the issue since it has no grease zerts.
I took clutch pedal linkage apart, polished the moving parts then greased them.
Adjusted clutch pedal to 5 1/2'' (wasn't far off)
Put it back together and pedal still sticks.
The throw out bearing is the next thing I can think of, any other ideas?
If I have to split this tractor to work on this problem would you replace clutch while in there?
I've never split one of these so any tips would be greatly appreciated.
Thanks
   / 2005 TN 70A Sticky Clutch Pedal #2
Before you resort to splitting the tractor (which you may well end up doing anyway) lube the clutch cross shaft with your favorite penetrant where the shaft is supported in each side of the clutch housing.
I'll give it a shot, nothing to loose.
Thanks
I'm usually slow to respond, working outside most of the time and don't get to my computer sometimes for days.
Wouldn't happen to know if there is a brass bushing in the cross shaft where it goes into the bell housing?
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
378764 (A51573)
378764 (A51573)
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
