2005 TN 70A Sticky Clutch Pedal
   / 2005 TN 70A Sticky Clutch Pedal #1
RW444
New Holland T70
Tractor has about 2400 hrs and transmission is a mechanical shift 12 speed
The pedal started sticking not wanting to engage smoothly which causes jerky engagement, with the tractor running the pedal always comes out but when not running you can engage clutch, release and the pedal will stop about half way out.
I thought the linkage might be the issue since it has no grease zerts.
I took clutch pedal linkage apart, polished the moving parts then greased them.
Adjusted clutch pedal to 5 1/2'' (wasn't far off)
Put it back together and pedal still sticks.
The throw out bearing is the next thing I can think of, any other ideas?
If I have to split this tractor to work on this problem would you replace clutch while in there?
I've never split one of these so any tips would be greatly appreciated.
Thanks
   / 2005 TN 70A Sticky Clutch Pedal #2
Before you resort to splitting the tractor (which you may well end up doing anyway) lube the clutch cross shaft with your favorite penetrant where the shaft is supported in each side of the clutch housing.
I'll give it a shot, nothing to loose.
Thanks
I'm usually slow to respond, working outside most of the time and don't get to my computer sometimes for days.
Wouldn't happen to know if there is a brass bushing in the cross shaft where it goes into the bell housing?
2018 F150 (A56436)
2018 F150 (A56436)
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
John Deere 2555 Tractor with Loader (A57453)
John Deere 2555...
2018 HINO 338 26FT CDL REQUIRED BOX TRUCK (A59575)
2018 HINO 338 26FT...
