2005 TC 29 DA Ignition Switch replacement
/ 2005 TC 29 DA Ignition Switch replacement #1
ranger13256
northville, ny
New Holland
Hi all,
My saga continues. I replaced the battery cables and thought that my starter problems were solved but not so. Still randomly clicking so I decided to upgrade the ignition switch to the NAPA KS6600. I was able to find one for $ 50 with my military discount and thought that it would be a simple fix. So far not so. To start with, the NAPA switch does not fit the whole in the dash very well, too small, but I can improvise a fix for that. A bigger problem is getting the switch to turn on the glow plugs. My tractor has 4 wires coming out of the original switch, 1 orange, 2 red, 1 white. I can get the accessories to work, the starter to work, but no glow plug light when the switch is in that position. Any ideas? A you can see, my options to go back to the original switch are a bit limited based on the fact that I had to moficy the connections. I think that I tried every combination of wires to switch posts to no avail. Any ideas will be greatly appreciated!
/ 2005 TC 29 DA Ignition Switch replacement #2
I would look this thread over as the originator got it working.
I just successfully installed the NAPA KS 6600 switch in my 2005 NH TC29DA. As suggested, I connected both red wires (B&D) to BAT, one white wire to ST, one orange wire to IGN. Everything works as it should, I don't know how but it does. The tractor starts every time so far. Thanks all for the advice!
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
Bobcat A770 (A60462)
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
John Deere 1025R (A64126)
John Deere 1025R...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
