2005 Late B series fuel leak
   / 2005 Late B series fuel leak #1
yellowdogsvc
Platinum Member
S. Central TX Hill Country
I have had problems with the rubber grommet on the tank leaking fuel. It has been replaced several times and just started leaking again. Anyone know of a better solution? That rubber grommet comes out easily and I also notice that when the tank is full it leaks worse (tank expansion?)
Thank you for ideas!
   / 2005 Late B series fuel leak #2
Thanks for the 'heads up'. The same thing happened several years ago on one of my TC's. The dealer fixed it while it was in for service and has never happended again that I'm aware of. Considering the daily increase in fuel costs, I will now be checking all three TC's before the next storm.
I guess I should have asked others for their ideas on how to fix it.. :)
I noticed after we had a really hard freeze (down in the teens) the tank started leaking again. It is possible I have a crack higher up and it is leaking too but I know it's dripping from the fuel line rubber fitting where it leaves the tank.
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2024 JOHN DEERE 461M LOT NUMBER 62 (A53084)
2024 JOHN DEERE...
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
2021 CATERPILLAR 289D3 SKID STEER (A51246)
2021 CATERPILLAR...
