2005 JD 5103 hour meter
/ 2005 JD 5103 hour meter #1
deerefan
Veteran Member
louisiana
1952 8N, 2005 JD 5103
My hour meter has stopped working. All other gauges work. Is there a universal hour meter you would recommend and how would I go about hooking it up? Thanks
Yes the alternator is good.
/ 2005 JD 5103 hour meter #4
Look for a 12v hour meter on Amazon or eBay. It will have two wire hook up, ground and 12v. Find a source (wire) from your key switch that is only "hot" in RUN for the 12v wire..
Will do. Thanks for the guidance.
/ 2005 JD 5103 hour meter #7
How to....remove 1 fuse and switch tractor on....check dash.....if not replace that fuse and switch off .....remove another fuse and switch on again ...if nor replace fuse and switch off. Do that till you went thru all .
Sorry for the delay. All fuses good.
/ 2005 JD 5103 hour meter #10
2005 5103 should be a mechanical hour meter in the tach no fuses. Otherwise a plain jane electrical hour meter would be your cheapest option.
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2012 KENWORTH T800 TRI-AXLE (A67714)
2012 KENWORTH T800...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A66736)
2022 Ford F-150...
2021 WEILER K560 KNUCKLEBOOM LOADER (A65057)
2021 WEILER K560...
