2005 JD 5103 hour meter
/ 2005 JD 5103 hour meter #1
deerefan
louisiana
1952 8N, 2005 JD 5103
My hour meter has stopped working. All other gauges work. Is there a universal hour meter you would recommend and how would I go about hooking it up? Thanks
Yes the alternator is good.
/ 2005 JD 5103 hour meter #4
Look for a 12v hour meter on Amazon or eBay. It will have two wire hook up, ground and 12v. Find a source (wire) from your key switch that is only "hot" in RUN for the 12v wire..
Will do. Thanks for the guidance.
/ 2005 JD 5103 hour meter #7
How to....remove 1 fuse and switch tractor on....check dash.....if not replace that fuse and switch off .....remove another fuse and switch on again ...if nor replace fuse and switch off. Do that till you went thru all .
Sorry for the delay. All fuses good.
/ 2005 JD 5103 hour meter #10
2005 5103 should be a mechanical hour meter in the tach no fuses. Otherwise a plain jane electrical hour meter would be your cheapest option.
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2015 RWF Bron HSII Cable Plow Attachment (A68183)
2015 RWF Bron HSII...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2437 (A65640)
2437 (A65640)
2022 ASV RT135 MAX-SERIES SKID STEER (A65056)
2022 ASV RT135...
2027 . . (A67714)
2027 . . (A67714)
