2005 JD 4320 pto looses power implement is engaged
   / 2005 JD 4320 pto looses power implement is engaged #1
erickperry
John Deere 4044R
My son in law has our old 4320 and after the pto is engaged and the implement is lowered to the ground, the pto power slows down and stops. He has been told it could be the solenoid, any others have this problem? How did you fix it? Thanks!
   / 2005 JD 4320 pto looses power implement is engaged #2
There’s nothing binding up the pto shaft when you lower it? If you raise it back up as soon as it starts to die, does the engine come back to normal?
Does it do it for all implements?
Nothing is binding it when lowered. The engine does not lose power, rpm's remain steady. If I raise the implement, the pto will gather up speed in a few seconds and it's back to normal, until the implement is lowered and I start to brush hog or roto til. So, yes, it does it for all implements.
   / 2005 JD 4320 pto looses power implement is engaged #4
Sounds to me like a plugged fuel filter or a restriction on the fuel line or trash in the tank blocking fuel flow.
The engine never bogs down, it's only the PTO shaft that slows down.
   / 2005 JD 4320 pto looses power implement is engaged #6
The the pto clutch is slipping and is shot and you don't want to know how involved that is to replace...As in splitting the tractor to renew it. Of ot still sort of working, I think I'd off it and buy another tractor.
OK, thanks, doesn't sound good!
   / 2005 JD 4320 pto looses power implement is engaged #8
Not all tractors have to be split to replace the pto clutch disc. Some you can pull from the rear.
Some are accessed from the side of the case.
However it looks like the 4320 may need to be split,
there is a thread on Green Tractor talk about trouble shooting the solenoid and valve.
4320 Bad PTO solenoid or valve?
   / 2005 JD 4320 pto looses power implement is engaged #9
And splitting the tractor would not cause me to get rid of it. It can be fixed.
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
2015 BMW 328i Sedan (A50324)
2015 BMW 328i...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52748)
NEW 2024 LOAD...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
Parker 400 bu Gravity Wagon (A50515)
Parker 400 bu...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
