2004 Scag TT 27hp Kaw- Randomly dying
   / 2004 Scag TT 27hp Kaw- Randomly dying
I have ruled out coils and vapor lock. Next up will be to test the fuel pump I guess.
Fuel pressure gage was going to cost as much as a new pump and filter so I just went ahead and replaced the pump and filter. Viola. Problem solved. Could instantly tell I had power back. And ran for 45min with out dying.
   / 2004 Scag TT 27hp Kaw- Randomly dying #13
So do you think it was the filter or the pump?
Did you ever disconnect the hose at the pump and try cranking to see if it was getting flow?
I think it was the pump. Not sure why it would die when hot if it was the filter. The filter was also full when I took it off.
Also, in my diagnosis I realized it's a 25hp, not a 27 lol. 🤷
I also had to cut the pigtail off the old pump as the oe kawasaki pump had a different clip 🙄
   / 2004 Scag TT 27hp Kaw- Randomly dying #17
   / 2004 Scag TT 27hp Kaw- Randomly dying #19
Fuel injected then? O2 sensor?
Not familiar with some of the newer stuff.....but 10-15 year old stuff....the only electric pumps were on the injected stuff. And Im only familiar with the kohler injected stuff
I questioned that too as I assumed all carbd motors were vacuum. But I am no mechanic. This is the motor, and the pump I bought. My Scag is a 2004 so its an older engine. But the same specs as the one below. Runs great I put about 100hrs a yr on it and the oil is still clean when I change it in the spring. I would like to stab the engineers who placed the oil drain where it is. Ordering a fumoto valve for it so next year i dont spend an hr cussing the paint off the walls.
FD750D | Kawasaki Engines USA
https://www.amazon.com/dp/B0BC8P3Z3L?psc=1&ref=ppx_yo2ov_dt_b_product_details
RIGID TOOLBOX (A50854)
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
International 4700 Vibra Tiller (A51039)
International 4700...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
1269 (A50490)
1269 (A50490)
