2004 JD 4310 hydraulic fluid foaming
   / 2004 JD 4310 hydraulic fluid foaming #1
70bluenova
John Deere 4310
2004 JD 4310 hydraulic fluid foams while using hot or cold weather. when you push on pedal to move forward, it hesitates. Also the front loader is jerky and any rpm. i was trying to plow the snow off the drive and would start to move then seem like it ran out of power to move , so i stoped and went backwards with no problem
any ideas or help would be greatly appreciated
   / 2004 JD 4310 hydraulic fluid foaming #2
Somewhere the system is sucking air. The problem will most likely be on the suction side of the hydraulic circuit. For the FEL check the rubber boot from the transmission housing to the hydraulic pumps on the left hand side of the engine just in front of the starter. One pump is for the power steering and the other is for the hydraulics. Also check to make sure the bolts holding the hydraulic oil filter inside the transmission are snug enough to prevent leaks.
As far as the hydrostatic transmision issues go I have no advice other than to make sure there are no issues that are mentioned above.
Thanks for the info and will check the areas for any possible air leak.
I did replace the screen in the transmission / suction line . old one was very dirty even after washing out. It also had some small hole in the screen around filter, and replaced fluid
   / 2004 JD 4310 hydraulic fluid foaming #5
Also check the fluid level.
2011 FORD F-650 SUPER DUTY (A48992)
2011 FORD F-650...
2016 Ford F-550 4x4 Dump Truck (A48081)
2016 Ford F-550...
2010 CAT 305C CR Mini Hoe (A49251)
2010 CAT 305C CR...
2016 MACK CHU PINNACLE (INOPERABLE) (A48992)
2016 MACK CHU...
Case International 4WD Tractor (A49251)
Case International...
2015 Ford F-450 Knapheide Service Truck (A48081)
2015 Ford F-450...
