2004 2840 WorkHorse Rear tire spacing adjustment ??
   / 2004 2840 WorkHorse Rear tire spacing adjustment ?? #1
Arizona
2004 Workhorse 2840
The left rear tire is sticking out past the left fender by about 3 inches. The right rear tire is centered perfectly under it's fender. I don't see how wheel spacing is adjustable. The hardware at each end of both rear axles looks similar to each other.
Yes the fenders are bolted down tight.
TIA !
Mike
   / 2004 2840 WorkHorse Rear tire spacing adjustment ?? #2
Flip the rim if turf tires. If ag tires, they'll need to be dismounted to keep rotation correct. The rim is dished more on one side then the other.
These ag tires and wheels are mounted the same on each side.
   / 2004 2840 WorkHorse Rear tire spacing adjustment ?? #4
Measure the fender stand-off of each side.
Measure rear axle flange face to side of gearbox, each side.
Fender stand off ??
1996 Chevy 2500 - Cheyenne Edition (A50515)
1996 Chevy 2500 -...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52748)
2017 Ram 5500...
1999 Toyota Avalon Sedan (A50324)
1999 Toyota Avalon...
377811 (A48836)
377811 (A48836)
2012 John Deere 7230R (A52748)
2012 John Deere...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
