Oil & Fuel 2003 BX23 -- UDT fill plug location
/ 2003 BX23 -- UDT fill plug location #1
scirocco
BX23 and P-D 218
hello all, thank you for reading!
I've just acquired a rough, but running 2003 BX23. At least, the engine code 3Y which seems to be Dec 2003, so maybe it's a 2004 model year?
Anyhow, the Hydraulic/Trans/UDT fill plug is not where I expected it to be based on the workshop manual I found. However, the manual I have is dated 2017, so.... makes sense.
The plug on this older machine is a large plastic threaded plug right in the middle/top of the back of the case --- very inconvenient to get a funnel into, and it has no dipstick.
QUESTION: How do I know how much to fill? Besides no dipstick, it isn't even possible to really observe inside to see the oil level.
Secondary Question: Does anyone have the correct WSM for this model year tractor? Unfortnately the factory sticker on the frame rail is scraped/damaged.
Pasted are the WSM page i'm referring to, and the numbers from the machine.
Thanks for any insight!
/ 2003 BX23 -- UDT fill plug location #2
I am not personally familiar with the BX machines, but transmissions without a dipstick should have a sight glass somewhere lower on the case to check the level. It's also possible (?) a previous owner replaced the OEM fill cap with something without an integral dipstick? There must be a way to monitor the trans fluid level.
Thank you very much TMGT! Indeed that thing is near-invisible.
Not sure why I thought there weren't going to be small changes over so many years.
/ 2003 BX23 -- UDT fill plug location #5
No problem, they did make it confusing by having a 23 and then going back to using the 23S designation 12yrs later.
Sent from my SM-S921U using TractorByNet mobile app
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
2016 CATERPILLAR 330FL EXCAVATOR (A60429)
2016 CATERPILLAR...
Gravely Pro Turn 460 60in. Zero Turn Commercial Mower (A59228)
Gravely Pro Turn...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
