2001 kubota bx 1800 hard to start
   / 2001 kubota bx 1800 hard to start #1
steeevo
plymouth maine
2001 kubota bx1880
I bought this tractor this spring, works well just takes 8-14 trys to start it.. like the fuel isn't getting though.. i'm thinking change the fuel filters. what do u guhs think?
   / 2001 kubota bx 1800 hard to start #2
I would suggest checking the glow plugs to make sure they are good and heating. How does it do once it warms up, does it still take 8-14 tries to start?
   / 2001 kubota bx 1800 hard to start #3
Make sure you change both fuel filters, there are two. Also make sure the lift pump is working, you should hear it clicking when you turn the key on.
after it start up and runs- it will start right back up easy.
ya it clicks..
   / 2001 kubota bx 1800 hard to start #6
Check the glow plugs or get new ones. If it starts good when warm, glow plugs are probably the problem. You can make sure they get voltage first, to make sure the system is working.
   / 2001 kubota bx 1800 hard to start #7
Do you let the gl plugs warm up for 10-20 seconds before cranking? Do you move th throttle lever to about 1/3 throttle, (not low idle)?
My BX1800 fires right up for me every time, but my son insists on cranking it immediately, at low throttle, and complains that it's hard to start... it's about the proper procedure.
Confirm proper operation of glow plugs as well.
   / 2001 kubota bx 1800 hard to start #8
I’d add to check all fuel hoses and clamps, I’ve chased similar issues that ended up being air intrusion into fuel system.
Mike
   / 2001 kubota bx 1800 hard to start #9
It seems like in my experience unless it’s cold you shouldn’t need the glow plugs, say 50 degrees or less, you need them.
(2) 275 Gallon of Resinator Clean/Dust Down (A51573)
(2) 275 Gallon of...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
Hustler Raptor SD (A51573)
Hustler Raptor SD...
John Deere 5400 Tractor with Loader (A51573)
John Deere 5400...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
