2001 GMC Yukon XL
/ 2001 GMC Yukon XL #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
I have posted before on the maintenance items I planned to do. So far I have put a couple of tires on, new shocks, flushed the power steering, front end alignment, new surpentine belts. The truck has 160K miles.
We are fixing to go on a week long trip and will put about 2000 miles on it. Wish I had flushed the coolant but haven't done that since 80K, about 4 years ago. Also, the transmission has not been flushed since 80K miles, and the fuel filter is probably 3 years old (had to change it out when the fuel pump went bad). The truck has the original spark plugs, wires and distributor cap.
It runs and drives fine. If I manage to get some of this done in the next couple of days, what would be the most important? And what is the most likely to fail on a long trip with an old vehicle like this? Keep in mind right now there are no symptoms, no noises, nothing. Just a check engine light that has been on for about 5 years, off and on.
How long do wheel bearings last on these trucks? I read where you don't pack em, and when you replace them you do the whole hub assembly and it is about $350 per wheel if you have it done. Not really what I'd call a preventative maintenance item at that cost so I figure you wait for noises to worry about that.
Or, we can elect to drive the 06 Honda Accord. It "only" has 138K on it. The Yukon is way more comfortable however, even though its just me and the spouse.
/ 2001 GMC Yukon XL #2
When we decided to drive to New England in our then 110+K Impala, I changed my AAA to the Gold plan, and that prevented any problems.
Chuck
/ 2001 GMC Yukon XL #3
I own the same vehicle but with the high trim level that gives me autoride suspension. These are great vehicles. The 5.3 engine is very efficient and dependable, the 4l60e transmission has been time tested and is also dependable. The vehicle has no special quirks or weaknesses. You've maintained it at least as well as GM requires with exception of the plugs. Those plugs, IIRC, are supposed to be swapped at 100,000 miles. I'm on my original plugs with about 120,000 miles on them and no issues but if you're looking for the next thing to do then that's it.
The SES light has stored a code on the computer and you should find out what that is. It might be simple like a tighter gascap or it might be important like O2 sensors.
/ 2001 GMC Yukon XL #4
Not only would I change the plugs but I'd have the tranny serviced also.
/ 2001 GMC Yukon XL
There is a Pepboys nearby and talked to them. The one guy advised against any kind of trans service before a long trip.
But I plan to have the following done tomorrow:
Spark plugs and wires $295
Coolant flush $90
Fuel filter $90
Fuel system clean $90
Could do just the plugs for $133 or just wires for $225, will do both for $295
Total with tax and $35 shop fee about $620
This will be over $2000 spent on the truck in the last 2 months - no breakdowns, just maintenance.
Bought the truck new exactly 9 years ago today for $35,000 (Sticker was $43K). Be hard to replace it for less than $45K or so.
/ 2001 GMC Yukon XL
Uh oh. Mrs. Alan L. just called and has had the transmission FLUSHED at the car wash (yea they do all changes and such there all the time and seem to be OK).
Ok, so this should not have been done. She has left and the transmission is working fine right now she says, the question is, will it now fail on our trip. Should we even drive it and opt for the honda? Don't want to be stranded.
Just a misunderstanding, I had been talking about needing to deal with transmission service - changing it or not and so she is just trying to take this off of me, just to get it done.
At least this WAS done 80K miles ago (not 160k) and the fluid seemed OK, not burnt or stinky, so maybe it will be OK???????
I had just talked to Pepboys today and they said do NOT even change the fluid, much less flush the transmission.
Crap.
/ 2001 GMC Yukon XL #7
300$ for plugs and wires. This engine has individual little coils on the valve cover over each plug so the plug wire is about 6" long and extremely easy to access. The plugs are also right on top with super easy access. Wow, I know many people just don't want to turn wrenches but changing plugs and wires on this engine is aabout as hard as changing the oil.
It's good to see preventative maintenance.
/ 2001 GMC Yukon XL
Hmmmm.......I think its $92 parts for the wires and $133 labor if not changing out the plugs. I will glance under the hood and evaluate whether or not it looks like I could do it easily. If so I'll just get the plugs changed out. I have assumed the wires all came to a central location like the old distributor days.
/ 2001 GMC Yukon XL #9
I don't follow your advice from Pep Boys on not servicing tranny before a long trip??? Don't get the logic. Maybe someone on this board can fill me in. If I recall, transmission service should be done every 40-50k miles. Your had gone 80k since last service (before wife had a flush). I'm not a fan of getting a tranny flush especially w/80k on it. I prefer the complete service w/filter.
/ 2001 GMC Yukon XL
Well, got it all done, after about 150 miles the transmission is still doing fine. Wish us luck on our trip.
Unfortunately they did find a pretty big problem in what would seem a minor area - the parking brake. Frankly we almost never use it here on flat ground, but for the last several years we find that the pedal goes straight to the floor and the parking brake doesn't work. Turns out this model has a very poor design - brake shoes just for the parking brake that expand out to the inside surface of the regular brake rotor (disk brakes on all 4 wheels). Not only are the shoes totally worn out, but they have taken out quite a bit of metal from the inside of the rotor. The mechanic says its dangerous, but it was already near closing time and they weren't going to have time to fix it.
I did some reading and find this is a problem with this truck, it wears out in the first 40 or 50K miles when its not even be used because the shoes constantly rub metal.
Anyway, they said they would do shoes, pads, parking brake pads, and new rotors on the back for $250 (regular price $498 with tax) when I have time, a concession from them getting the truck out at 7PM when it was supposed to be ready by 2:00 and causing them not to have time to fix the brakes.
They offered to also knock $100 of the current day's service, but they worked hard to get it done so I declined and paid the extra $100. Stupid maybe, but I have clients myself and sometimes its a juggling act to please them all.
New Mexico and cool temps here we come....
/ 2001 GMC Yukon XL
Made our trip in the Yukon - about 1800 miles in all and no trouble with the tranny or any other problems. Great trip.
Gas mileage tanks: 17.9, 18.2, 18.3, 19.2
Not bad for 160K.
/ 2001 GMC Yukon XL #13
As far as that Pepboy's comment. I can only assume that they believed that you never had the fluid changed. i have also told others the same thing with 100K vehicles. if you never changed it, don't. Back when i was wrenching, I can't tell you the number of people who insisted that the fluid be changed and we pushed the car off of the rack. Of course they signed the disclaimer warning of this.
In your case, I'd say changing it was a good idea. As far as changing it before a trip, I can't see what difference that would make beyond the possiblity that the new detergents in the fluid would dislodge some gunk at high temperature. Possible I guess, but not common.
/ 2001 GMC Yukon XL #14
I changed my mine about vehicles a few years ago. I went to Disney world and on the way to the airport we were in an American van that had 650K miles on it. It was only a few years old but ran 24 hour a day 7 days a week. I asked the driver what was the secret? He said regular maintenance and they had vans from all three American makers so it wasn't just the make I was in and they all had at least 650K miles on them.
Since then I stopped selling my vehicles as they near 100K and have put a lot of extra cash in my pocket.
I also recently purchased a Ford 250 with a utility box and 40K miles that normally I would have passed on and it has been an amazing vehicle. All I did was put tires and shocks on it and she purrs like a kitten.
Sure wish I would have learned this lesson about 20 years ago.
/ 2001 GMC Yukon XL #15
Not sure if the Yukon is the same? Have you ever had the A/C system replaced? not to alarm you but you have the year model same as My Mother '01 only hers is the Tahoe, the A/C in hers started making a noise towards the end of last summer I replaced the tension pulley and resolved the noise for a short while, but started back and completely ruined the new one,
turns out is the A/C compressor is locking up, We took it to an auto mechanic and was told that this particular model ( '01 Tahoe ) had problems and actually a recall on the A/C systems, however was a time statue of limitations and could not get hers replaced, According to the mechanic seems GM design mistake having no room for the compressor up in the usual area had to put the A/C compressor lower at the bottom of the engine causing the oil in the compressor to buildup a hydro-lock, therefor locking up the compressor,
Anyways! thought I'd mention it.... may or may not apply to your Yukon,;)
/ 2001 GMC Yukon XL #16
Same thing happened to my 01 Tahoe...Occasional banging noise. I replaced the tensioner with the same result. Finally the belt blew off. Replaced that and no AC.
Bought it used, so any early convenience recalls were long gone.
Replaced the receiver dryer, orfice tube and compressor. The only problem I ever had with that truck...Still miss it. The wife wanted an H3, so that's what she got.
/ 2001 GMC Yukon XL
No A/C problems so far.
Actually I drove the whole way, wife had surgery in April and is not as comfortable driving long distances as she used to be.
The last tank was driving from about 9000 feet down to about 2000 so maybe that had something to do with it. But the middle two tanks were mostly no AC but the last day we went from 45 degrees in the morning to 104 in Texas in the afternoon.
Well, after the comment about the wife not being comfortable, she drove 400+ miles to Missouri today in the Yukon. Her Dad's father in law passed away at age 88 or so. I am too busy at work so I couldn't go since I just got back from 10 days off.
Her sister left her Lexus in the garage and I find that the dome light is on and its locked. She has the keys with her in Missouri so I bet that battery will really be dead when they get back.
/ 2001 GMC Yukon XL #18
You wouldn't happen to have AAA would you? One of the cool things I found that I had from AAA was emergency unlocking, and it didn't matter that it was my daughter's car that needed it.
Chuck
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
PANTHER T14R TRACKED DUMPER (A65056)
PANTHER T14R...
2011 JET  48 FOOT SPREAD AXLE STEP DECK TRAILER (A67714)
2011 JET 48 FOOT...
2009 POLAR TANK . (A67714)
2009 POLAR TANK ...
LANDPRIDE 48" BOX BLADE (A65057)
LANDPRIDE 48" BOX...
2011 DRAGON  4 AXLE CRUDE TRAILER (A67714)
2011 DRAGON 4...
