2000BD king pin
   / 2000BD king pin #1
FL_Jerry
FL, Bay County
YM 2000
I'm trying to replace the king pin seals and I'm having a little trouble
getting it out.
I remove the nut and washer from the top and removed the gear/bearing from under side. Only thing left is the shaft with the needle bearings.
Any tricks to getting it loose?
This may double post, but the first attempt didn't show up........trying second time.
   / 2000BD king pin #2
Jerry - If I knew the answer, I'd be sure to tell you - Someone will know though - Good Luck!
   / 2000BD king pin
I got one out, and good thing I did , seals are shot.
Thanks.
Jerry
   / 2000BD king pin #4
Jerry,
I was about to suggest that the only item that could be hanging up the king pin would be the wood-ruff key. Once that is removed it's often necessary to de-burr, file, or clean up with emery cloth, the key way on the king pin.
I've had them slide right out after a little touch up...of course in the real world it takes a little persuasion from a big dead-blow or lead hammer.
Good luck,
Mark
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
3 point Woven Wire Rack (A53117)
3 point Woven Wire...
2024 Homemade Enclosed 16ft S/A Cargo Trailer (A51694)
2024 Homemade...
22ft Rollback Flatbed Body with Winch (A54814)
22ft Rollback...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
