200 hour service: BX2360
   / 200 hour service: BX2360 #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I'm at 212 hours; ye olde handbook says I need to change the Transmission Oil Filter. Do I really ? I did the coolant change @ 2 years and the stuff looked new. I know there's a thread around here about not losing a bunch of fluid...
   / 200 hour service: BX2360 #2
Follow your manual, the trick is to use a shop vac on the fill hole to keep oil in the tank.
   / 200 hour service: BX2360 #3
Regarding Anti-Freeze, I change mine every 4 years. If you look at your manual close enough, it advises that you change the hoses every 2 years when you change the anti-freeze.
   / 200 hour service: BX2360 #4
I usually skimp on the antifreeze recommendations. But not so much on the oil. I would definataly change the oil and filters when they say. But me personally, if I am changing the filter, I go ahead and change the oil too.
But if you just do the filter, take the fill plug off first and put a shopvac over that hole. (turned on of course) The internal vacuum it creates will hold the oil in place and not make a huge mess when you take the filter off.
The shop vac trick worked great. I lost a little bit out of the filter and that was it.
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A51572)
2016 Hino 195h...
2013 Cadillac SRX SUV (A50324)
2013 Cadillac SRX...
