200 hour service: BX2360
   / 200 hour service: BX2360 #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I'm at 212 hours; ye olde handbook says I need to change the Transmission Oil Filter. Do I really ? I did the coolant change @ 2 years and the stuff looked new. I know there's a thread around here about not losing a bunch of fluid...
   / 200 hour service: BX2360 #2
Follow your manual, the trick is to use a shop vac on the fill hole to keep oil in the tank.
   / 200 hour service: BX2360 #3
Regarding Anti-Freeze, I change mine every 4 years. If you look at your manual close enough, it advises that you change the hoses every 2 years when you change the anti-freeze.
   / 200 hour service: BX2360 #4
I usually skimp on the antifreeze recommendations. But not so much on the oil. I would definataly change the oil and filters when they say. But me personally, if I am changing the filter, I go ahead and change the oil too.
But if you just do the filter, take the fill plug off first and put a shopvac over that hole. (turned on of course) The internal vacuum it creates will hold the oil in place and not make a huge mess when you take the filter off.
The shop vac trick worked great. I lost a little bit out of the filter and that was it.
2016 Ford E-350 Econoline Cutaway Service Van (A46683)
2016 Ford E-350...
2014 UTILITY 53X102 DRY VAN TRAILER (A45678)
2014 UTILITY...
Farmall A Tractor (A49251)
Farmall A Tractor...
2016 Ford Explorer AWD SUV (A46684)
2016 Ford Explorer...
ST253/80R16 Radial Tires (set of 4) (A49251)
ST253/80R16 Radial...
Wolverine TCR-12-48H SKid Steer Trencher (A47371)
Wolverine...
