200 cx pallet forks?
/ 200 cx pallet forks? #2
yes, they take the same forks as the 300 and 400 series loaders.
/ 200 cx pallet forks? #5
I bought Horst pallet forks for around 700. I purchased the light duty forks for a 200cx on a 2320. Given the lift capacity is around 1000 lbs I did not see a need to go heavier / larger.
If you talk to your dealer or Horst they can quote a delivered price and they will paint them deere green if you like. I've been very pleased with them.
HORST WELDING
/ 200 cx pallet forks? #6
I have the Frontier 42" fixed tine forks on my 2320. They work great.
/ 200 cx pallet forks? #7
I have the Frontier 48", since that is what the dealer had. Work great. I would recommend the 42" thou.
/ 200 cx pallet forks? #8
Prices have gone up, especially on the 48" forks, expect $800-900
/ 200 cx pallet forks? #9
I have the Frontier 42 inch, fixed-tine forks on a 200CX on a 2520 and love them. One of my favorite attachments.
They cost $655 two years ago. List price was $755, I believe.
/ 200 cx pallet forks? #10
Another recommendation for the Horst forks. Probably my most used attachment.
/ 200 cx pallet forks? #11
The 200 and 300 have the same pin/hook dimensions the 400 are different/bigger. I see now the newer forks have 2 sets of pins so they will work for the 200-400 series, my earlier model Horst forks only had the one set of pins.
I vote for the Horst cast pallet forks as well, I paid over $900. for mine, but when compared to the Deere ones I liked the Horst better, bought them from Deere dealer.
JB.
/ 200 cx pallet forks? #12
the 400 uses the same pins as the 200 and 300 series. look at the buckets they use, they are the same part number.
the 500 series utilizes the "lower pins" offered on the newer pallet forks, so now they can sell one set for many loaders.
/ 200 cx pallet forks? #13
Ok I could be wrong but I thought this was discussed before and that was the correct answer, anyway I've never even seen or heard of 500 series loaders so shows you what I know :)
JB.
/ 200 cx pallet forks? #14
ya either way not a big deal jb, i guess the main question here was answered!!:)
/ 200 cx pallet forks? #15
Well, that depends on which "400 series" you are talking about.
The older 210,410,420,430 loaders, as well as the 200xx, 300xx all use the same setup. The newer 400xx loaders do indeed use the lower pins and share the same dimensions as the 5xx series QA setup.
/ 200 cx pallet forks? #16
ok you are wrong here kennyd.
I have a new 2520, 200cx with 61" bucket. the part # on bucket is bw14146.
That same bucket is available for 200x, 200cx, 300x, 300cx, 400x, 400cx. look in jdparts.
will also work with the 210,410,420,430, and i believe the 460(not 100% sure on that one)
my 2520 with 200cx
my dad has 3320 with 300cx. 73" BUCKET
my brother has 4720 with 400x. SAME 73" BUCKET
we share pallet forks between the three of us. ALL USE TOP PINS.
WE HAVE SWITCHED BUCKETS BEFORE.:)
THE 500 SERIES (A 512 FOR INSTANCE) USES THE BOTTOM PINS.
/ 200 cx pallet forks? #19
after looking at that kennyd i sounded kinda mean....its no big deal i appreciate all the help you and everyone offers on here!!!
hard to find this kind of knowledgebase anywhere else!!!:)
/ 200 cx pallet forks? #20
No worries. I am a big boy and can readily admit when I am wrong. Unlike some others, I appreciate being set straight if I give misleading info.
2015 John Deere 323E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2024 CRUISER RV SHADOW CRUISER (A67714)
2024 CRUISER RV...
PALLET OF MISC MOTORS AND PARTS (A67714)
PALLET OF MISC...
2014 Ram Pro Master 2500 Cargo Van (A66736)
2014 Ram Pro...
