20' X 24' Pole barn on 25% slope - best method?
   / 20' X 24' Pole barn on 25% slope - best method? #1
DwayneB2021
Ohio
Kubota BX1500
Hello to the forum - thanks in advance for any input. I read a number of other threads on the forums here about how to approach placing a pole barn on sloping ground, but not sure any of them really addressed my particular situation. Essentially the entry to the barn is at grade level (20' wide) and the ground slopes away at 25% along the 24' depth. Which means the "rear" corners of this floor would be 6' high.
See the attached images showing side views, they show two different approaches to build this barn:
1) Local contractor claims they can dig a ditch around the perimeter, then build up a retaining wall with very large rip-rap "boulders", then fill the interior with compacted gravel, then pour a slab, then build a pole structure above the slab. This has advantages of being able to park a car or truck in the barn if needed, although mostly this will be used to store a BX1500 tractor and other equipment. Disadvantage is having a huge pile of ugly rip-rap under this building (will be visible from the road). And not certain that this rip-rap "boulder" retaining wall will truly remain stable for the long haul.
2) Amish barn builder suggested a post building supporting a reinforced wood platform. This would use 6" by 6" posts, (about 22 total) with a post row under the center of the floor. The floor would be tongue-in-groove covered by plywood. Advantage is that this is much cleaner appearance on the outside (no giant walls of rip-rap). Disadvantage is that while it would easily hold a tractor and implements, might not be adequate to support a car or truck. Not a "forever" building, but would surely last as long as I am kicking.
The Amish guys are a little pricier. But I have seen their work on other barns in the area and it is excellent.
Any thoughts about either of these approaches or alternative approaches?
Appreciate any ideas you might have.
   / 20' X 24' Pole barn on 25% slope - best method? #2
It would add $$$ to the building, but footers and a 4' poured concrete wall (actually foundation) would be the most attractive or at least look like normal house or garage construction.
Then there's simply getting some fill dirt to level this "pad" and the gradually sloping away so it could be mowed.
I'd take a guess that the concrete option might be $3-4000 and somewhat make this building look taller, at least from the back. Also your builder will need to switch from post holes and use the steel brackets to attach the posts to the concrete. That may add a few bucks for the building but it might be a "wash" as it means no hole digging and might eliminate the need for pt lumber.
I don't like putting wood in the ground anymore, I just don't trust the new treatment and one day it will rot and fail.
   / 20' X 24' Pole barn on 25% slope - best method? #3
Side hill?
Dig into the side hill wider and deeper than than the pole barn. Dig & fill method. Get a nice gentle back slope to the excavation. If suitable use the excavated material to pad out in front of the excavation. Finally make a drainage ditch around the side and back of the excavation. Then use ordinary building procedures With cement floor.
Six foot depth may/will end up as less using cut & fill method.
Going to do this one time so the $$$ are not really an issue.
It's a good suggestion, had thought of this but I wasn't sure about the post construction on top of a standard foundation with footers. I had read somewhere about "wet anchors" for posts to be placed in the concrete slab, but you'd have know with total certainty where you wanted them.
Share the same concern about any wood in the ground. Probably OK for 5 years or so but beyond that, as you say eventually it will degrade.
Problem with any of these contractors it is hard to find someone who will do the whole job. Some do concrete only, some do pole structures only, and so on. Getting a little too long in the tooth to tackle a project like this myself.
   / 20' X 24' Pole barn on 25% slope - best method? #5
I was just wondering where that 36" side entry door was opening out to? Seems to be that first step might be an issue. I agree with Rustyiron, putting wood in the dirt nowadays isn't as good of an idea as it used to be. In Florida it is even a worse idea, since you didn't include your location. I do know your not in Florida, because we don't have many of this types of issues, and rocks of that size to back fill the building.
David from jax
Side hill?
Thanks for the suggestion. I've heard about this method, and I guess you could excavate into the hill,and use some of that material to "pad up" the rearward downslope area. Seems like the main advantage of that method is reducing the amount of fill - although the concrete pad still needs to be at grade on the left in these sketches, so wouldn't volume of fill be the same? Seems like you would still need a retaining wall of some sort around this earthen pad which will be supporting the concrete floor (and the weight of equipment). This is a clay area when you get down a foot or so. That stuff is pretty greasy, over time gravity will try to slide the concrete pad/gravel/earth fill on down the slope unless you have some retaining wall, especially on the downhill side.
David from jax
David - yes you are right we will need to build up some steps to reach the side door. Main entry would be the 16' garage door to the left in these sketches, which will be ~on grade. I am in Ohio, so subject to frost/freeze. Have to get down 36" or more with any sort of footer. Wood in dirt even if treated is not ideal, agreed. I've been thinking about this project for a while now, unfortunately it's the only spot for a building on my property.
   / 20' X 24' Pole barn on 25% slope - best method? #8
6’ high on the downhill end is near my comfort limit for a pole barn base where you put in posts at grade (footers below frost line) but not out of the question. I’ll go take a pic of one I did that was about 3’.
Basically you build the pole barn normally but need longer posts on the downhill portion. At some point after it’s framed, you bring in self compacting gravel (#57 or #78 is my preference) and backfill and level the floor. The gravel spills out under your skirt board at a normal angle and forms a sloped berm around the barn. Once done, cover the gravel with a compactable material on the outside to finish the berm to the desired grade.
Instead of a sloped berm you can instead (or in combination) build a retaining wall on the downhill end.
   / 20' X 24' Pole barn on 25% slope - best method? #9
This link might give you some ideas . or some links for your research :)
When you say your comfort level, what's your concern about the 6' downslope height? Is it the pole length? These have to go 4' in the ground, so it would be a really long pole for sure. 10' just to get up to floor level, then another 15' or so above that. Can they even get a 6X6 25' post?
I hadn't heard this approach to filling inside the post array and allowing the gravel to naturally slope outward. Are you thinking about a concrete slab on top of that #57/#78 gravel?
One builder was proposing lining the post array with tongue-in-groove and filling gravel inside that box. I really didn't like that idea, because once that wood degrades/rot, the wall would burst outward. I guess if you made the box walls with 2X12 treated planks with moisture barrier that would be pretty substantial. But not a "forever" solution.
Thanks for this idea it's a new one I had not heard about.
30 Yard Roll Off Container (A51573)
30 Yard Roll Off...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
24'' Mini Excavator Bucket (A51573)
24'' Mini...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
