Snow 20" Too Much Snow
/ 20" Too Much Snow #41
Charlie-
I was thinking that the "too hot" condition resulted from hours of current passing through the solenoid, rather than external temperatures.
I think new ones are in the $50 or less range, since it is a standard Bosch part, but I have seen some folks asking $320 for it, so check your part #s, and try to cross reference.
Merry Christmas!
Peter
Now that I've wired around the seat switch, I'll use the shutoff switch as you suggest. I was wondering how I was going to do that.
On inspection last evening, I confirmed that the lever is just a kill switch, not hooked to the solenoid.
And, the solenoid worked properly after resting overnight. I guess it could have gotten pretty hot with several hours of plowing, but the temp gauge wasn't showing hot. Outside temp was about freezing. On occasion when I have gotten the engine hot mowing, it has been hard to restart and I've had to let it cool. Maybe the solenoid is sensitive to heat.(If it malfunctions again, I hope it will be in the run position.)
HAPPY HOLIDAYS
/ 20" Too Much Snow #42
I purchased one of the "new" designs from my local Deutz distributor and it was over $200 plus an adapter wiring harness that brought the total delivered to more than $250.
You may recall I posted about it at the time--the problem wasn't the solenoid--rather a bad ground.
/ 20" Too Much Snow #43
Ouch.
Memo has the new style ones for $147.
Oregon fuel injection has ones for $46.50-$140, but they need the part numbers off of the solenoid itself. (Makes me concerned that the lower price is for a different unit.)
All the best,
Peter
/ 20" Too Much Snow #44
Ouch.
All the best,
Peter
What is the URL for Memo?
/ 20" Too Much Snow #45
looks like farm23's original thread has officially been hijacked.....
2013 Infiniti JX35 AWD SUV (A61574)
2013 Infiniti JX35...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
2012 Mini Cooper Coupe (A61574)
2012 Mini Cooper...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
(4) ASSORTED TIRES (A62613)
(4) ASSORTED TIRES...
GROUND SAW (A64276)
GROUND SAW (A64276)
