20 inch chainsaw recommendation
   / 20 inch chainsaw recommendation #101
Hi All,
I need to buy a new chain saw. I have a Husky 18 inch that is around 22 years old or so and the trees I need to cut up are too big for it. I figure a Husky or Stihl but open to other ideas as well. I would like to go with either brand's middle line, not home or professional but I think it is called Rancher series.
Secondly are there good online discount sites to buy or is buying local at a box store, hardware store TSC etc better?
Thanks so much,
Glenn
I have an Echo Timberwolf. Has been great
   / 20 inch chainsaw recommendation #102
One vote for a Stihl MS400C
After crushing my MS-361 (59cc, 12.3 lbs, 4.6 hp), I replaced it with a MS-400CM (66.8cc, 12.8 lbs, 5.4 hp)
Both running a 20" bar. I'm very happy with the 400CM
   / 20 inch chainsaw recommendation #103
Seems like the saw sizes are ratcheting up.
The OP is currently running an 18” saw.
Maybe it’s time to recommend a 80CC 36” saw? 😁
   / 20 inch chainsaw recommendation #104
That stihl is a 50cc saw, the husqvarna is a 60cc saw, of course the bigger saw is heavier.
So that means they aren’t comparable. That was my only point.
K ?
   / 20 inch chainsaw recommendation #105
Get something with a compression release. I have a Husq 345. It isn't very powerful but it has an adjustable carb (with limiters removed) and a compression release. Whatever you get, if it lasts, you will wish it had a compression release.
That’s a really good, overlooked point.
I hear a lot of guys here complaining the can’t pull the starter on their saws. A compression release solves this prob.
   / 20 inch chainsaw recommendation #106
De-comp valves can end up leaking and sucking in air (= BAD). Really should only need them on larger saws (because they're totally necessary). IF you have one on a saw you should check them religiously.
Again, mentioning a "brand" is meaningless unless specifying the exact model. Someone noted that they'd use Stihl if cutting every day, well, NOT if you're using a consumer-grade Stihl. Sorry. What one wants FIRST is "Professional" grade, then pick your "Ford" or "Chevy" brand (based on service availability etc.).
Also, what bar size one is using is mostly meaningless. If you want to know what to get then SPECIFY what type of work it needs to do FIRST. While longer bars tend to keep one upright more they also require more sharpening activity (chains and bars are going to be more expensive), tend to find dirt quicker unless one is careful and are hard to swing around in tighter quarters (more danger to oneself- more bar and more chain to come into contact with). A saw that does 100% of what one needs doesn't exist (unless one is dealing with a tree plantation or such- all the trees are the same, the cutting conditions are the same). Get what can reliably do 90% of what you need to do, perhaps push it 5% more and use another saw/tool for the remainder. Anyone who does a lot of cutting is going to have multiple saws of differing sizes*.
* I'm kind of an oddball here in that I have four saws but only two sizes (ended up with three of the same saw- they're the perfect saw for 90% of what I deal with).
I did break down and buy an electric pole saw (DeWalt). This was a great pick-up. Has made dealing with low-hanging limbs much easier: have cut via regular chainsaw from a tractor bucket- now just stand in the back of my Polaris and reach up with the pole saw).
   / 20 inch chainsaw recommendation #108
Worst starting saw is my Stihl 192 (whatever it is). It's an "easy-start" saw I got for my wife. BUT, it's only really bad if you do not start it correctly- one cannot rip on the cord w/o flooding it (at which point it's a mess to get started). One has to just slowly pull on the cord as if chug-chugs and pops. Great saw otherwise: perfect for doing a lot of small branch work- not a top-handle but the top-handle one is one a lot of folks would used up in trees. Have had this saw just a bit longer than my oldest 562xp.
   / 20 inch chainsaw recommendation #109
That’s how the easy start works, pulling the cord is literally just winding up a clock spring that spins the engine over when you get to the end of the pull. If you just yank on it like a normal pull start it won’t work and will damage the starter. It’s not a great system on a saw though IMO, but I have it on my backpack blower and it’s awesome, don’t have to take it off my back to re-start it.
   / 20 inch chainsaw recommendation #110
I have a 40 year old Stihl 076AV with 32, 36 and 54 inch bars that has cut several thousand cords of wood it never fails to start on the 3rd pull if it hasn't been used, 1 or 2nd otherwise. Also have an 026PRO and a 251 that always start by the 2nd pull with 24 and 26 inch bars that are wonderful lighter saws, only brand I will buy.
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
New/Unused CFG Industrial QH12R Mini Excavator (A57453)
New/Unused CFG...
JOHN DEERE 469 BALER (A58214)
JOHN DEERE 469...
LOT: (4) Pairs of Tire Chains, Fits Tire Sizes: 11R-22.5, 285/75-22.5, 295/75-22.5, 275/80-24.5, ... (A59076)
LOT: (4) Pairs of...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
