2 way splitter design?
/ 2 way splitter design? #1
Rio_Grande
Platinum Member
I have been looking at the wood splitters that split in two directions. How are these made? I have been interested in building one but cant find opne in this area to get my eyes on. I like the effiency of splitting in bith directions.
Jeff
/ 2 way splitter design? #2
A friend of mine built one of these once and I rented it from him. You would not believe how much wood you could split in a day, but you need 4 or 5 people to keep wood to it and away from it plus operate it :confused2: :thumbsup: :D
/ 2 way splitter design? #3
Basically the cylinder is inside a box beam with a slot cut in the top for the wedge to stick through. They use a smaller and shorter section of box beam that just fits inside the larger beam. The wedge and cylinder rod are hooked to it. It keeps the wedge somewhat straight as to not put a lot of bending load on the cylinder. Keeps it pushing more or less straight.
there are a couple of drawbacks to that design though.
1. More expensive to buy/make
2. Less force in return
3. As already mentioned, you need more people to operate it more efficently than a conventional, and thats ONLY if you are splitting some tough stuff. When splitting easier wood like red-oak, ash, cherry, etc, I rarley even have to extend the cylinder half way before the wood pops. Say I have a 24" cylinder. 10" of stroke will split most of the easier stuff. Now if you had a bi-directional splitter, would you just retract it back that 10", of extend it the remaining 14" just to split on the return?? And even the stringier stuff like elm that you have to go almost all the way, it is still usually retracted by the time I have the next peice ready.
I have tossed around the idea of building a splitter for myself for some time now. Since I already have the 27t with 4-1/2" cylinder, I would make one out of either 3-1/2 or a 4" cylinder. But I would like to find a cylinder like off of heavy equipment with a HUGE diameter rod. Something like a 3" rod and 4" cylinder would give VERY Quick retract times.
/ 2 way splitter design? #4
I would also recommend using a two stage hydraulic pump (that pumps faster when not under load)
Thanks for the replies. I will do some more looking.
/ 2 way splitter design? #8
Rio_Grande,
You haven't said if it will be a stand alone, or 3pt using the tractor hydraulics.
Would be stand alone, All the tractor mounted units I ever used were slow. I am looking for something that will keep up with me. Just dont like standing there waiting for cylinder to retract.
/ 2 way splitter design? #10
A 3PT splitter with a fast extend log splitter valve by Prince is plenty fast, but can only be used with a standard hyd pump. Does not work with 2 stage.
Of course that depends on the GPM's of the tractor.
Fast extend give about 50% more speed, decreased cycle time.
I wasnt aware of that possibility JJ, My tractor while 57 hp is only 11 GPM. I have thought about the various options like a PTO pump and the like. I just dont like the Idea of running my 574 at a high enough RPM to get max output on the pump. The reason is, I can get better use out of the life of my tractor by using it as a tractor insted of a hydraulic power source. Nothing against anyone who does it that way, just think I could buy several small engines and pumps as opposed to rebuilding the diesel in my tractor.
I am sitting here with a busted knee right now waiting on surgery and for once in about three years I have time when I cant do anything but think. Got me rethingking a few of my projects that have yet to get off the ground. All I am lacking for a standard splitter is the correct valve and pump. I have everything else gathered up. This is item #2 of 4 In front of that is getting my bender converted to hydro because I will use it for various parts on the splitter.
Thanks again for the input.
/ 2 way splitter design? #12
I have the Powerhorse two way splitter with a two stage pump.It is truly an awesome machine and very efficient.As stated earlier,to realize it's full potential,you need multiple guys.One operating and at least two bringing and removing wood.Although I operate solo mostly,it's still better than a conventional design.True if the wedge only goes in a couple inches before the log splits you can just retract,but with two stage it only takes one or two seconds.I would be glad to answer any questions about it.
1137 (A63291)
1137 (A63291)
1055 (A63291)
1055 (A63291)
Jacobsen LF510 5 Gang 100in. Commercial Reel Mower (A61572)
Jacobsen LF510 5...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2020 Ford F-150...
