2 stage pump?
/ 2 stage pump? #1
wvpolekat
Platinum Member
Buckhannon, WV
1947 Ford 2N and 2003 Kubota B7500
I am looking at adding a hydraulic pump to my 47 2N for various light duty uses, like lifting a blade or something similar.
Seems like there are quite a few 2 stage pumps for a reasonable price. (< $200)
But, couple of questions:
1) Ok to drive with a belt? If these were designed to be coupled to a motor, will they stand up to the lateral force of a belt? Or should I just look into mounting it off the crank?
2) Will they work for this kind of thing? Seems like they would be almost perfect for something like this, where most of the time it would be low pressure.
/ 2 stage pump? #2
most 2-stage pumps are made for logsplitters and for that reason designed for a lovejoy coupling or similar, so I do not recommend to use belt drive.....radial force will wear on shaft seal, bearing and gears.....
pump manufacturer/vendor should recommend appropriate/possible way to drive the pump
/ 2 stage pump? #3
On my 8n (recently sold), the hydraulic pump was mounted and driven by the front shaft from the motor. It lived between the engine and the radiator :)
It operated the FEL (whose arms were actually the reservoir for the hydraulic fluid)
- JC
2022 John Deere 6R 140 Tractor (A66285)
2022 John Deere 6R...
2004 Chevrolet 2500HD (A66408)
2004 Chevrolet...
2004 Chevrolet Silverado 1500 Pickup Truck (A64556)
2004 Chevrolet...
2011 JCB 4x4 Backhoe 3CX14-4-T (A65579)
2011 JCB 4x4...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
