2 single acting cylinders 1 remote
   / 2 single acting cylinders 1 remote #1
thendrix
ball ground, ga
allis chalmers ca
I want to build a hay accumulator out of an old trailer frame and I need to be able to work 2 tables with 1 remote (2 ports 1 handle. Handle up activates 1 port handle down activates the other port). My thought is to have a ramp with an elevator chain, probably a #55 floor chain, that is ground driven some how. The bales will "climb" the ramp and when 2 reach the top end to end I will activate 1 single acting cylinder to "flip" the bales onto the main table. When the handle is released the small table will return "home". When the main table is full I want to use another single acting cylinder to dump the bales and when I let go of the handle the main table returns "home". Think something similar to a very small bale wagon. Make since? I may need a spring or something to help the tables return quick enough but that's yet to be seen. Thoughts?
Like this
https://m.youtube.com/watch?v=yxA3CpRvna0
I realize this isn't exactly what I described but this is the general idea
   / 2 single acting cylinders 1 remote #2
I think you could IF once your first table is (gravity) back down in a resting or bottom'd out, then your second cyl is the same before you could use the 1st. again. (By moving the valve to the other position, either extended cyl. will retract)
If you need to leave a table "up", a simple "selector valve" with 4 ports - one for each cylinder and 2 (supply & return) from your existing valve will work, a little cumbersome to operate though. Should be about $70.
   / 2 single acting cylinders 1 remote #3
Sounds too much like needing another pilot to operate it. If you're making it mechanically driven, why not make the whole operation mechanical and skip the hydraulics? If the operation is timed to the "ramp", you just hop on the tractor and drive. No need for constantly watching and working valves. Or have the mechanism activate the valve automatically. The older I get, the more I look for ways for tools to save me work. :)
There's lots of different ways to put ground driven power to use. Old differentials, sprockets and chains, etc. And funny thing about hydraulic wheel motors. They're just as happy pumping fluid as they are turning wheels or sprockets.
   / 2 single acting cylinders 1 remote #4
You will need some sort of selector or "diverter" valve, to do what you want.
Then there is no way for the fluid in the cylinders to get back to the tank.
   / 2 single acting cylinders 1 remote #5
Could you explain that? When the valve is activated one direction, the other port is opened to valve output. Hopefully, the output is routed to the tank.
The SA cylinders will need some hefty springs to return with any speed though. I wouldn't rely on gravity unless the table(s) are a couple hundred pounds.
   / 2 single acting cylinders 1 remote #6
You are correct...I blame morning fuzz :laughing:
BUT: I'd still suggest some type of selector/diverter, so he can have independent control of the two cylinders, otherwise every time one cylinder is actuated-the other will retract.
   / 2 single acting cylinders 1 remote #7
After re-reading the OP, a single valve won't work for what he wants though. Sounds like he wants the cylinders activated independently from one another with a single valve. No can do. :confused3:
Let me explain my thinking a little. On my tractor you pull the handle up to activate one port and down to activate the other. This may be what is meant by 2 remotes? I was under the impression that 2 remotes would have 4 ports. I don't understand why with this setup I would have to have the small table home before activating the large table? If the cylinders return due to gravity or Springs or whatever then I should be able to activate the large table while the small is coming down. Can't go the other way because there's nowhere to put the bales with the big table up. The big table will probably be roughly 9 to 10 ft by 3 to 4 feet framed with 2x2 tubing and a sheet metal top. I'm guessing it will weigh a couple of hundred pounds. The small table I'm sure won't weigh enough to return home fat enough without help. It will be 6 to 7 feet by 20 to 22 inches. There's no need to leave one up and activating the other as the small has to work before the big one. I'm thinking the biggest hurdle will be getting the small table back down fast enough to not have to crawl on the tractor. I'm not looking for a speed demon but more then a slug. Bales are usually spaced about 30 ft or so apart maybe a little more and I would like to run around 5 or 6mph. Not comfortable going faster due to the terrain. Check out the link I posted originally. That's my idea but doing it with hydraulics rather then switches
   / 2 single acting cylinders 1 remote #9
Thendrix,
On your existing valve you have two work ports that I will call "A & "B". When you move the lever up pressure goes to "A" & "B" is connected to tank. When you move the lever down Pressure goes to "B" & "A" is connected to tank which is how a double acting cylinder works.
Like others have stated you either ned more valving or got mechanical.
   / 2 single acting cylinders 1 remote #10
You have just 1 Dual Acting remote.
The point is that when one cylinder is extending-look at the orange side in the drawing Ken posted above, the blue side will be open to the tank and will want to retract-and vise-versa. You cannot move just one cylinder by itself.
Gold Mining Equipment (A57454)
Gold Mining...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
Metal American Flag (A57454)
Metal American...
2006 MAC TRI AXLE 37 X 102 DUMP TRAILER (A59575)
2006 MAC TRI AXLE...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
