Planters 2 Row Planter
/ 2 Row Planter #1
19977
Smyrna,Delaware
JD 4520
Hi all,I ran across a company " Myron Graber Planters"out of Secor Ill. They will make any size planter for me.Anyone heard of this company?If i do order one ( 2 row )any,ideas on how it should be made,as in planter row width ,36",30" ect..I know theres alot of knowledge out there ,so any help would certainly would be appreciated.
Thanks Mike
/ 2 Row Planter #2
Did a google search for them on the web and couldn't find anything on the planter. So I can't say much there. If I had more time I am sure I could find something on the web. But setting the row at 36" seems high to me. Some of the corn packs I had this year told me to not go any wider than 30" for proper pollination. So I planted at 36" anyway by mistake??? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif We'll see how it turns out.
murph
/ 2 Row Planter #3
People can talk about the pros and cons of row width forever, but for what we are doing, hobby farming, you need to look at the practical side of it. How wide are your tires, center to center?
If they are 40" then you can use 20"rows
If they are 48" then you can use 24" rows
If they are 60" then you can use 30" rows
If they are 72" then you can use 36" rows
Of courese it can work with other multiples of these but the your tire spacing must be matched to your tire width or else you are going to be running over rows that you already planted.
/ 2 Row Planter #4
We have always kept veggie rows on 36" centers. As long as you plant a block of corn instead of a couple of rows they'll be fine pollinating.
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
New/Unused 20ft X 20ft Steel Carport (A65583)
New/Unused 20ft X...
Westendorf 8' Loader Bucket (A66408)
Westendorf 8'...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
International 2000 Front-End Loader (A66408)
International 2000...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
