Quick Hitches 2" receiver lift arms
   / 2" receiver lift arms #1
Stillhunter
Slippery Rock, PA
New Holland TC33D, MF 165
Does anyone know if there are cat 1 lift arms fabricated to fit into a 2" receiver on the market? These would be used in clamp-on receivers on my fel. Thanks
   / 2" receiver lift arms #2
Not sure how you mean, but you could put a horizontal 3pt lift pin, instead of a ball, on a short 2in square tubing or ball mount. Then use a regular lift arm.
Bruce
Bruce, thanks for the reply. Perhaps I am misinterpreting your reply, but I want the ball socket end of the lift arms to come out of the receivers. That way, I can use the clamp-on receiver to hook up to implements via the receiver mounted lift arms.
   / 2" receiver lift arms #4
Diagram added to previous post.
Bruce
Bruce, I got it now, thanks. However, seems these arms won't provide lift as they will pivot on the lift pins. Just looking for a simple 1 piece lift arm that will lock into the receiver and thus not pivot.
Roger, thanks for the reply. I don't want to take my bucket off my tractor to use implements so this one wont work. But again, thanks.
I guess if there is nothing on the market, I could get lift arms welded to the sides of 2" stock though I would rather have the arm centered in the receiver so as not to put sideways torque on the receiver.
   / 2" receiver lift arms #9
If I am picturing this corretly, I think there is nothing on the market because it dont sound like a good way to mount an implement but it does sound like a good way to tear things up. All the weight of the 3PH on a little reciever tube mounted in the middle of the bucket??
Basically, if I understand correctly, you want a 3-point hitch hookup, mounted on a "frame" of some sort, with a 2" square stub that you could insert into a reciever tube mounted on the fel bucket right??
What exactally are you trying to do??
Actually, I want 2 lift arms to fit into 2 clamp-on receivers (not 1 in the center) to allow me to have lightweight/low stress implements on both the front and back of the tractor at the same time. Note, I have the top link attachment resolved.
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2013 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2013 FREIGHTLINER...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
