2" receiver attachments
/ 2" receiver attachments #1
dqdave1
N. E. Ohio
tc- 29d
2\" receiver attachments
Thinking about welding a 2" receiver on the top of my FEL bucket to attach different attachments. Will posters please let me know (with photos) what they have created (besides the obvious trailer ball) so I can get ideas and copy if interesting. Thanks
/ 2" receiver attachments #2
Re: 2\" receiver attachments
Try the search option. It requires a little bit of effort, but is more effecient than having lots of people go take pictures.
Another idea is to start a thread called something like POST YOUR pICTURES OF 2 INCH RECIEVER THINGS.
I did such a post on forks. It has many many posts.
Good luck with your search.
I made a vise and also a cargo carrier for my reciever. Also works on the truck reciever.
/ 2" receiver attachments #3
Here are my receivers. All I have right now is a set of hooks. One of these days I am going to make a spill guard to go into them if I ever have time.
Thanks for photo; Did not think to install more than one; first idea is to mount three.
I hoped most posters would already have photos of there project. I did a search but it was not giving me much in results.
Forks are one idea I hope can be attached to a 2" receiver ( or two)
/ 2" receiver attachments #7
I saw a toilet seat attachment in Farm Show....handy on a bucket...wouldn't even get your tires "muddy". /forums/images/graemlins/blush.gif
/ 2" receiver attachments #8
I've been looking at doing this for a long time, one thing is I want to (Once the shop floor is in and done) start building a few items for myself one being a grapple, for this reason I was thinking 3 of them spaced across my bucket so that the grapple section could slip into these instead of needing perminate brackets on top. that way boom poles , forks, ect could all use these as upper attachments. /forums/images/graemlins/smile.gif
though for strenght reasons I was looking at using a 3/8" x 10" x 48" hunk to reinforce the bucket top and attach the misc reciever tubes too. (top of my buucket is about 10" I think so sizes above are just for referance.)
anyhow I have to get the barn done this spring/summer so I can move items in better than just gravel and no lights now ect.
mark M /forums/images/graemlins/tongue.gif
/ 2" receiver attachments #9
You may want to check the latest Northern Tool Catalog. One came in the mail just this evening and there are more than a couple of receivers for buckets (clamp type). maybe you can get an idea or two from their products.
/ 2" receiver attachments #10
I will try to post a pick soon. I posted a pic of some forks I built yesterday. I have a 1.125" rolled rod across the top of my bucket. With that the top of my bucket is strong. I have a 2" receiver under the rod in the middle. I built a jib poll that goes past my bucket about 6’. On the end I have a plate welded with a chain hook on the end. In the plate there is a hole that I use a large shackle for cable slings. The pole is mad of 1/4" x2" square. I have a gusset across the top made of 2"x1/4" strap. It is made to were the gusset goes to the back of the pole behind the receiver.
To in stall in the receiver you slide in while pulling up on the back of the gusset. Once it slides in all the way you pin with the receiver pin. Next come the 2 grade 8 bolts + one 1/2 pin that secure the back of the gusset. It is made strong the gusset is the full length. I know all of this is hard to follow I will try to post a pic soon.
I built this for 2 main jobs. 1st to place the rails and span up for my bridge Crain in my shop. The rails are 50" 8"x13lbs I beam. I needed to pick them up 14'. I also made a pair of I beam tongs that I hang on the chain hook of the pole.
2nd was I used to harvest pecans we would load the nuts in large super sacks 2000lbs+. The bottom of the sack would have to be picked up 5' off the ground to run the nuts in the cleaner. So the had to bee higher than just the FEL would go.
I have not made me a hayfork yet for the receiver, but I am soon.
John
/ 2" receiver attachments #11
6; lenght out on the FEL will be a LOT of added lever weight to lift that 2000 *******. I once could tell that weight with a calculation on the fel point and remember that the life point of mose fels are rated at somthing like center of the vucket...
mark M
/ 2" receiver attachments #12
Yes it is allot of weight. But when stacking the big sacks you could stack 2 high 3 deep. If you are moving a bight load a long way like a nut sack out from the field. You would tilt the bucket down so you could see the hanging loading fork. Then as you would raise the bucket you would tilt it up. What would happen is the nut sack would come to rest on the bucket. The pole sticking up at around a 25 deg angle. You can rotate it straight up if needed. I had to build it to pick the sacks up high. So the sacks were not always out at 6' out front. I would do that when loading or stacking.
John
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A65563)
2016 Hino 195h...
Applegate Creep Feeder (A66408)
Applegate Creep...
Skid Steer Tree Spade (A65640)
Skid Steer Tree...
(5) Husqvarna Weedeaters and Leaf Blower (A65579)
(5) Husqvarna...
Hedge Posts (A65640)
