2" receiver attachments
/ 2" receiver attachments #11
Re: 2\" receiver attachments
6; lenght out on the FEL will be a LOT of added lever weight to lift that 2000 *******. I once could tell that weight with a calculation on the fel point and remember that the life point of mose fels are rated at somthing like center of the vucket...
mark M
/ 2" receiver attachments #12
Yes it is allot of weight. But when stacking the big sacks you could stack 2 high 3 deep. If you are moving a bight load a long way like a nut sack out from the field. You would tilt the bucket down so you could see the hanging loading fork. Then as you would raise the bucket you would tilt it up. What would happen is the nut sack would come to rest on the bucket. The pole sticking up at around a 25 deg angle. You can rotate it straight up if needed. I had to build it to pick the sacks up high. So the sacks were not always out at 6' out front. I would do that when loading or stacking.
John
Chandler Equipment 18' Litter Spreader (A60462)
Chandler Equipment...
2023 GMC 1500 Seirra Elevation Crew Cab 4X4 Pick-up Truck (A60352)
2023 GMC 1500...
CFG Inudustrial MH12RX (A60463)
CFG Inudustrial...
1991 International 4900 Box Truck (A55315)
1991 International...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A61165)
2007 Chevrolet...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
