2 questions re: groinding
/ 2 questions re: groinding #1
rtd
Athens, Ohio
Ford 3930 - Kubota L3430 - Kubota B2150 - YM155D
1) What do you use to grind a flat surface? A typical 4 1/2" grinder with the tapered laminated 'sandpaper' disk comes to mind and it might be better than a standard wheel but it's not really for flat surfaces. I've thought that a belt sander might be a possible choice. What have you used with success?
2) Sometimes the appearance of the finished weld and adjacent surfaces is important, and a typical grinder can't get to all the surfaces that need to be cleaned-up. What do you use for this detail grinding work? I've thought of a Dremel or something like it but I don't know if these small tools can take the side pressure. How have you solved this problem?
Thank you
/ 2 questions re: groinding #2
Really depends on exactly what I want to do, then I pick one of these to work with.
/ 2 questions re: groinding #3
Once you sharpen your welding skills, little grinding needs to be done. I dont grind my welds. The paper discs you describe are really for blending the weld into the work. if you have a lot of overweld or burn in, it's difficult to blend the welds into the work. that's the beauty of Tig welding. There is also a needle scaler that hammers your welds and it will leave a hammered look. Other than that it's Cut offs, blenders, Wire wheels, grinding wheels and discs, carbide burrs, cup stones and scotchbrite pands, There are few other options. I would say look at fine grit cup stones for flat surfaces.they go on your grinder and do a good job on flat surfaces.. Another possible one is an encapsulated wire cup brush but it wont remove material like a cup stone. Good luck..
/ 2 questions re: groinding #4
When I have a special nook or corner, I use some sort of Tungsten deburring tool on an air powered die grinder.
I know it's likely a typo, but for a moment I thought the title might be a Freudian slip? Got a little tight in there with the grinder and slipped maybe? :shocked:
Thanks for the replies.
Yes it's a typo in the subject line, and yomax4, my welding skills do need improvement.
I'm looking into die grinders; any specific recommendations for use or those to stay away from? I'm generally inclined toward Makita or Bosch.
/ 2 questions re: groinding #6
I was playing football and got a real bad groinding one time. Hurt for hours!
/ 2 questions re: groinding #9
I'd really go with an air powered one. ANY air powered one is as good as the more expensive electric ones in my experience. I have a higher end Campbell Hausefeld. IF you bog it down, it won't smoke the brushes. :)
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
Unverferth Field Cultivator (A64127)
Unverferth Field...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
Stout Brush Grapple XHD84-6 (A66285)
Stout Brush...
7102 (A61567)
7102 (A61567)
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
