2 cyl vs. 3 cyl
/ 2 cyl vs. 3 cyl #1
usedcarz
nw ohio
kubota zd-21, jinma, kioti
some of you jinma owners give me some pros and cons on the 2 cyl. 20's and 22's versus the 3 cylinders. is it really worth the extra $$ for the 3 cylinder?
/ 2 cyl vs. 3 cyl #2
The three cylinder 224 uses the Y380 engine, which is nearly identicle to the Y385 used in the 254/284. Difference is the bore size, 80mm vs 85mm. The main differences between 2cyl and 3 cyl is 2 cyl develops more torque at lower rpm. The 3 cyl is smoother running, and develops it hp at higher rpms.
/ 2 cyl vs. 3 cyl
thanks john. just ordered 6 tractors and the 2 cyl. are in the 204's and 224's can't see the extra money for the 3 cyl. unless there was a GREAT advantage. to me, the buyers on these size tractors are after price and what they get for the money vs. smoother running. the 20hp 2 cyl i had did a spectacular job for what it was.
John Deere 6400 (A64126)
John Deere 6400...
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
John Deere Hay Spear (A64126)
John Deere Hay...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
