2 cyl vs. 3 cyl
/ 2 cyl vs. 3 cyl #1
usedcarz
nw ohio
kubota zd-21, jinma, kioti
some of you jinma owners give me some pros and cons on the 2 cyl. 20's and 22's versus the 3 cylinders. is it really worth the extra $$ for the 3 cylinder?
/ 2 cyl vs. 3 cyl #2
The three cylinder 224 uses the Y380 engine, which is nearly identicle to the Y385 used in the 254/284. Difference is the bore size, 80mm vs 85mm. The main differences between 2cyl and 3 cyl is 2 cyl develops more torque at lower rpm. The 3 cyl is smoother running, and develops it hp at higher rpms.
/ 2 cyl vs. 3 cyl
thanks john. just ordered 6 tractors and the 2 cyl. are in the 204's and 224's can't see the extra money for the 3 cyl. unless there was a GREAT advantage. to me, the buyers on these size tractors are after price and what they get for the money vs. smoother running. the 20hp 2 cyl i had did a spectacular job for what it was.
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
John Deere 980 30' Field Cultivator (A66285)
John Deere 980 30'...
Kiefer Built Livestock Trailer (A66285)
Kiefer Built...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
