2 cyl vs. 3 cyl
   / 2 cyl vs. 3 cyl #1
usedcarz
Bronze Member
nw ohio
kubota zd-21, jinma, kioti
some of you jinma owners give me some pros and cons on the 2 cyl. 20's and 22's versus the 3 cylinders. is it really worth the extra $$ for the 3 cylinder?
   / 2 cyl vs. 3 cyl #2
The three cylinder 224 uses the Y380 engine, which is nearly identicle to the Y385 used in the 254/284. Difference is the bore size, 80mm vs 85mm. The main differences between 2cyl and 3 cyl is 2 cyl develops more torque at lower rpm. The 3 cyl is smoother running, and develops it hp at higher rpms.
   / 2 cyl vs. 3 cyl
thanks john. just ordered 6 tractors and the 2 cyl. are in the 204's and 224's can't see the extra money for the 3 cyl. unless there was a GREAT advantage. to me, the buyers on these size tractors are after price and what they get for the money vs. smoother running. the 20hp 2 cyl i had did a spectacular job for what it was.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
