3-Point Hitch 2 bottom plow
   / 2 bottom plow #1
Narothgeb
Will a 4310 pull a 2 bottom plow?
   / 2 bottom plow #2
Yes
But that depends on how good you want the plowing job to be, and what tranny and tires you have on the 4310.
Tell us more....
   / 2 bottom plow #3
How much you plowing 4wd I presume? I used to pull a two bottom with my 4wd L2850 kind of comparable to a 4310 very slow going. Then I got a old L4150 much easier and did a better job in my experience
   / 2 bottom plow
It’s an ePowrReverser with ag tires. Tires are not filled. Has a 300c loader.
   / 2 bottom plow #5
Should work if you can get the tire spacing right.
What plow you have in mind? Pic would help. There should be some good adjustments to get it to plow good.
   / 2 bottom plow #6
I pull a 4 bottom with trips regularly with a 4630.
   / 2 bottom plow #7
Depend's on soil so your guess is better than mine. No way 30 horse pressure can pull 2 bottoms here but less than 30 miles in one direction and 40 in another they do it all the time. You might get a better idea by giving it a try.
   / 2 bottom plow #8
John Deere 4310 Weight
2,600 lbs
1179 kg (2WD)
2,900 lbs
1315 kg (4WD)
Max Drawbar:562 lbs
254 kg
Max front axle:1,588 lbs
720 kg
Max rear axle:4,410 lbs
2000 kg
Dimensions
Wheelbase:68 inches
172 cm
Length:117 inches
297 cm
Width:50 inches
127 cm
Ground clearance:13.4 inches
34 cm
   / 2 bottom plow #9
If your Deere 4310 has 2-WD it will pull a two-bottom moldboard plow of 12" width through reasonably moist soil.
If your Deere 4310 has 4-WD it will pull a two-bottom moldboard plow of 12", or 14" width through anything.
If your Deere 4310 has 4-WD it will pull a three-bottom moldboard plow of 12" width through reasonably moist soil.
A 16" width plow moves almost twice the dirt, relative to a 12" plow.
   / 2 bottom plow #10
According to Tractordata a JD 4630 has 127 db HP & weighes over 16,000#s I've pulled 6X14 moldboard with my JD 4255 rated at 112 db HP & weighes over 12,000#s BUUT both these models are rowcrop tractors while OP's tractor is a much smaller frame utility model
I'll wager a JD 4310 MFWD can't pull a 3 bottom moldboard in my soil type.
2018 FORD F-350 SUPER DUTY (A45333)
2018 FORD F-350...
New/Unused 12ft x 7.4ft x 8.2ft Container (A44391)
New/Unused 12ft x...
2010 Toyota Camry Sedan (A42744)
2010 Toyota Camry...
2007 PETERBILT 387 (INOPERABLE) (A45046)
2007 PETERBILT 387...
2017 Ford Explorer AWD SUV (A42744)
2017 Ford Explorer...
2016 FREIGHTLINER SD122 (A45046)
2016 FREIGHTLINER...
