2 bottom plow Q's
   / 2 bottom plow Q's
Re: 2 bottom plow Q\'s
Thanks! Know if a "hillside" plow could be used in a typical garden? Saw one in the local ads yesterday...
   / 2 bottom plow Q's #12
Also you're forgetting that 40 hp tractor probably had twice the torque of the 30 hp tractor. I've got a 40 plus hp old AC 45 that will outpull most tractors twice it's horsepower.
   / 2 bottom plow Q's #14
In addition to Ken's comments on a 2-bottom plow being more stable than a 1 bottom plow:
Most plows are designed to plow about 1/2 as deep as the bottom is wide. For that reason, they always say a 3-14" plow will pull as easily as a 2-16" plow. While cutting wider, it is throwing less actual dirt. Likewise, a 2-12" plow should really pull easier than a 1-16" plow.
--->Paul
   / 2 bottom plow Q's
Thanks a lot for all the info guys. Ever hear of a 'hillside' plow? Found one in the ads and am wondering if it'll do what I need. $100, so it's worth considering.
   / 2 bottom plow Q's #16
Those AC 45's were a darn good tractor.
Egon
   / 2 bottom plow Q's #17
Hello--Sounds like a horse drawn plow---My Granddad had one when I was a kid--Ken Sweet
   / 2 bottom plow Q's #18
Hi Rich--20 Ferguson? I bet that some TBN guys may not know that you have a 20 HP 2 wheel drive tractor and coming up on 50 years old and still does what it is called upon to do!!--Looking back on my childhood, I dont know how we farmed 100 acres without Power Steering, Hydrostat,4x4,Live PTO and a Easy Ride Floation Seats. Seems we thought we were ahead of our neighbors because we had a VAC Case with narrow front and new fangled thing called "3 point hitch" and they had a H Farmall or B John Deere with only a belly drawbar to work with.--Ken Sweet
Sweet Farm Equipment Co.
   / 2 bottom plow Q's
I found a few like that too when I started researching them on the internet, but later found a few 3 point types. The ad said 3 point too.
From what I can gather, it has dual moldboards, but each one faces the opposite direction. Each one can be dropped depending upon which side downhill is when plowing the side of a hill. Try this link for a pic: Hillside plow on an 8N
- G
   / 2 bottom plow Q's #20
Hi G--If the one for $100 is styled like the one in the picture and has not been broke or welded up, you cant go wrong.--Ken Sweet
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A57024)
2023 Unverferth...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A55315)
2023 Kubota...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A55302)
2017 Ford F550...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
