2 bottom plow Q's
   / 2 bottom plow Q's #21
Re: 2 bottom plow Q\'s
cowboydoc - not sure about the torque but that Case sure could pull a load. I would pull a baler with a hay wagon behind that up some pretty steep Western PA hills. It had a triple range transmission.
We also had a Farmall M and it could pull a load also. It was bigger than the Case. But I am sure some of the new John Deeres have many times more pulling capacity than the old tractors that I operated in the early 60's.
John
John
   / 2 bottom plow Q's #22
There were those who prefered the swinging drawbar to the three point . The larger the tractor the less chance of having a three point hitch.
Egon
   / 2 bottom plow Q's #23
Hi Egon--In Ky, the 3 point was a blessing in the small tobacco and corn fields (1-10 acres)--Working the tractors in small fields,sometimes required 3-4 attachment changes daily--I can remember our neighbor taking 30 min+ to bolt on his sickle bar mower to the rear axle of his H Farmall and it took us about 3 min to hitch the sickle to our VAC Case 3 point, with no heavy tugging and lifting required--I realize that many larger row crop areas of the country had adapted to pull type implements and did well with them.--Ken Sweet
Sweet Farm Equipment Co.
   / 2 bottom plow Q's #24
We converted our Farmall M to 3PH but some of the standard 3PH implements did not work well on the Farmall because it had a very high profile. If I recall correctly, the rear tires were nearly 6 foot tall.
   / 2 bottom plow Q's
Yea, that's what I figured. But it looks like I'll never see it. He never called me back. Probably already sold... /forums/images/graemlins/frown.gif
   / 2 bottom plow Q's #26
I grew up in Alberta farming country where fields were very much larger. A model H was considered a small tractor despite those large wheels. A WD9 was a large tractor then and would now be considered medium or less.
Different circumstances/ different tools/ different definitions
Egon
   / 2 bottom plow Q's
Scratch that. He did call. I'm going to see it next Sat. It's a MF Model 55 two bottom hillside plow. I imagine it is similar to the one in my previous post, just with 4 instead of 2 'boards...
- Gerald
   / 2 bottom plow Q's #28
rule of thumb according to 1994 john deere farm management handbook is 15 hp per bottom and that agrees with what I have heard from other people along with time to plow an acre with a 4 bottom plow is an hour so I would guess it would take about 2 hours to do your 1/2 acre with a single bottom plow. which isnt bad for doing it once a year
I would suggest the 1-16 plow approach.
keep it easier on your tractor, storage maintenance, so on.
My 33 engine hp pulls a heavy cat. 2 trip plow OK but take it out of 4wd and no weight up front and its a waste of time.
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2020 John Deere 7230R (A53317)
2020 John Deere...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2008 Ford Escape XLS SUV (A55853)
2008 Ford Escape...
Club Car Utility Cart (A55853)
Club Car Utility...
