2 bottom plow Q's
/ 2 bottom plow Q's #21
Re: 2 bottom plow Q\'s
cowboydoc - not sure about the torque but that Case sure could pull a load. I would pull a baler with a hay wagon behind that up some pretty steep Western PA hills. It had a triple range transmission.
We also had a Farmall M and it could pull a load also. It was bigger than the Case. But I am sure some of the new John Deeres have many times more pulling capacity than the old tractors that I operated in the early 60's.
John
John
/ 2 bottom plow Q's #22
There were those who prefered the swinging drawbar to the three point . The larger the tractor the less chance of having a three point hitch.
Egon
/ 2 bottom plow Q's #23
Hi Egon--In Ky, the 3 point was a blessing in the small tobacco and corn fields (1-10 acres)--Working the tractors in small fields,sometimes required 3-4 attachment changes daily--I can remember our neighbor taking 30 min+ to bolt on his sickle bar mower to the rear axle of his H Farmall and it took us about 3 min to hitch the sickle to our VAC Case 3 point, with no heavy tugging and lifting required--I realize that many larger row crop areas of the country had adapted to pull type implements and did well with them.--Ken Sweet
Sweet Farm Equipment Co.
/ 2 bottom plow Q's #24
We converted our Farmall M to 3PH but some of the standard 3PH implements did not work well on the Farmall because it had a very high profile. If I recall correctly, the rear tires were nearly 6 foot tall.
/ 2 bottom plow Q's
Yea, that's what I figured. But it looks like I'll never see it. He never called me back. Probably already sold... /forums/images/graemlins/frown.gif
/ 2 bottom plow Q's #26
I grew up in Alberta farming country where fields were very much larger. A model H was considered a small tractor despite those large wheels. A WD9 was a large tractor then and would now be considered medium or less.
Different circumstances/ different tools/ different definitions
Egon
/ 2 bottom plow Q's
Scratch that. He did call. I'm going to see it next Sat. It's a MF Model 55 two bottom hillside plow. I imagine it is similar to the one in my previous post, just with 4 instead of 2 'boards...
- Gerald
/ 2 bottom plow Q's #28
rule of thumb according to 1994 john deere farm management handbook is 15 hp per bottom and that agrees with what I have heard from other people along with time to plow an acre with a 4 bottom plow is an hour so I would guess it would take about 2 hours to do your 1/2 acre with a single bottom plow. which isnt bad for doing it once a year
I would suggest the 1-16 plow approach.
keep it easier on your tractor, storage maintenance, so on.
My 33 engine hp pulls a heavy cat. 2 trip plow OK but take it out of 4wd and no weight up front and its a waste of time.
2026 Kearney 102"x32' Gooseneck Trailer (A64119)
2026 Kearney...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
(2) UNUSED 14X17.5 TIRES W/ 8 LUG RIMS (A64280)
(2) UNUSED 14X17.5...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
(3) MILITARY CARGO BOXES (A64281)
(3) MILITARY CARGO...
8ft. Teak Wood Table (A61574)
8ft. Teak Wood...
