2 bottom plow Q's
   / 2 bottom plow Q's #1
GSS
Pgh, PA
Cub Cadet 7360SS, MF1100 & JDx585
2 bottom plow Q\'s
I really need to get a small plow for the garden this year to complement my tiller. I've been looking for a decent one in the ads and auctions, but to no avail. Have any of you ever bought a new smaller plow? What brand and how much was it? What size would you suggest for a 30HP tractor and a small <1/2 acre garden? Thanks guys!
- Gerald
   / 2 bottom plow Q's #2
Re: 2 bottom plow Q\'s
Hello Gerald-We have access to new 2 bottom plows--however--they are not as well built and dont usually have the features as the older plows do.--for your reference-- here is a picture of a MF 2-12 autotrip plow that we have just rebuilt--Ken Sweet
Sweet Farm Equipment Co.
   / 2 bottom plow Q's
I have never actually used one before, but know I need to do more than till. What features should I look for in a newer or older plow? Would a 3 be too much for 30HP?
Thanks.
- Gerald
   / 2 bottom plow Q's #4
Hello GSS--I would think you would want auto spring trip beams(not shearpin or solid) and coulters and for sure replaceable moldboards,points,shins and landslides--Rolling furrow tailwheel would be nice but not essential--3 bottom would be way too much--Ken Sweet
   / 2 bottom plow Q's #5
Why don't you just buy a one bottom plow or middle buster? For less than a 1/2 acre garden that will do the job. Then run over it with your tiller. I'm not sure you could pull a two bottom plow anyway with only a 30 hp tractor.
   / 2 bottom plow Q's #6
I agree. I suppose if you have the right kind of soil, moisture, etc., a 2-bottom plow might be all right, but I know there was no way a 30hp tractor could have pulled a 2-bottom plow in my clay, wet or dry.
   / 2 bottom plow Q's #7
When I was a young guy we pulled two 14 inch plows through SW PA's clay soil without laboring. We had a Case 300 which I believe had a 40 HP gas engine and weighed about 4000 pounds.
I think there is a good chance that he could pull two 12 inch plows with a 30 HP tractor, especially it is gear drive. One thing about plowing, there is a fair amount of donward force on the rear tires which helps with traction.
I pulled a single 12 inch plow with my 9 HP, 1957 Power King. Plowed many of garden with the PK.
John
   / 2 bottom plow Q's #8
Yep, John, that old tractor was twice as heavy for traction as the compact tractors now. I used single bottom plows with my B2710 (27hp) and in some cases, just went along pretty easily, but usually had to use 4WD and occasionally the differential lock.
   / 2 bottom plow Q's #9
<font color="red">I know there was no way a 30hp tractor could have pulled a 2-bottom
plow in my clay, wet or dry. </font>
Hi Bird--Contrary to popular belief--usually a 2-12 (24 inch cut) pulls as easy as a 1 bottom 16 inch cut--The 1 bottom plows usually try to take too much land at each cut (18-24 instead of 16 inch) and the more you try to compensate for that on the 3 point, the more you will tend to get the plow off the centerline of the tractor, causing unnecessary pull to the right front of the tractor--The old TO 20 Fergusons and the 8 and 9N Fords use the 2-12 here in heavy red clay based soil with no problem.--Ken Sweet
   / 2 bottom plow Q's #10
Ken, I'll take your word for it. Of course, I didn't have an opportunity to try a 2-bottom plow with either of my compact tractors, and would not have wanted to try a 16" plow either. I had a 14" middle buster and just a 12" turning plow.
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
2006 Chrysler Town and Country Van (A51694)
2006 Chrysler Town...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
