2 bottom plow Q's
   / 2 bottom plow Q's #1
GSS
Pgh, PA
Cub Cadet 7360SS, MF1100 & JDx585
2 bottom plow Q\'s
I really need to get a small plow for the garden this year to complement my tiller. I've been looking for a decent one in the ads and auctions, but to no avail. Have any of you ever bought a new smaller plow? What brand and how much was it? What size would you suggest for a 30HP tractor and a small <1/2 acre garden? Thanks guys!
- Gerald
   / 2 bottom plow Q's #2
Re: 2 bottom plow Q\'s
Hello Gerald-We have access to new 2 bottom plows--however--they are not as well built and dont usually have the features as the older plows do.--for your reference-- here is a picture of a MF 2-12 autotrip plow that we have just rebuilt--Ken Sweet
Sweet Farm Equipment Co.
   / 2 bottom plow Q's
I have never actually used one before, but know I need to do more than till. What features should I look for in a newer or older plow? Would a 3 be too much for 30HP?
Thanks.
- Gerald
   / 2 bottom plow Q's #4
Hello GSS--I would think you would want auto spring trip beams(not shearpin or solid) and coulters and for sure replaceable moldboards,points,shins and landslides--Rolling furrow tailwheel would be nice but not essential--3 bottom would be way too much--Ken Sweet
   / 2 bottom plow Q's #5
Why don't you just buy a one bottom plow or middle buster? For less than a 1/2 acre garden that will do the job. Then run over it with your tiller. I'm not sure you could pull a two bottom plow anyway with only a 30 hp tractor.
   / 2 bottom plow Q's #6
I agree. I suppose if you have the right kind of soil, moisture, etc., a 2-bottom plow might be all right, but I know there was no way a 30hp tractor could have pulled a 2-bottom plow in my clay, wet or dry.
   / 2 bottom plow Q's #7
When I was a young guy we pulled two 14 inch plows through SW PA's clay soil without laboring. We had a Case 300 which I believe had a 40 HP gas engine and weighed about 4000 pounds.
I think there is a good chance that he could pull two 12 inch plows with a 30 HP tractor, especially it is gear drive. One thing about plowing, there is a fair amount of donward force on the rear tires which helps with traction.
I pulled a single 12 inch plow with my 9 HP, 1957 Power King. Plowed many of garden with the PK.
John
   / 2 bottom plow Q's #8
Yep, John, that old tractor was twice as heavy for traction as the compact tractors now. I used single bottom plows with my B2710 (27hp) and in some cases, just went along pretty easily, but usually had to use 4WD and occasionally the differential lock.
   / 2 bottom plow Q's #9
<font color="red">I know there was no way a 30hp tractor could have pulled a 2-bottom
plow in my clay, wet or dry. </font>
Hi Bird--Contrary to popular belief--usually a 2-12 (24 inch cut) pulls as easy as a 1 bottom 16 inch cut--The 1 bottom plows usually try to take too much land at each cut (18-24 instead of 16 inch) and the more you try to compensate for that on the 3 point, the more you will tend to get the plow off the centerline of the tractor, causing unnecessary pull to the right front of the tractor--The old TO 20 Fergusons and the 8 and 9N Fords use the 2-12 here in heavy red clay based soil with no problem.--Ken Sweet
   / 2 bottom plow Q's #10
Ken, I'll take your word for it. Of course, I didn't have an opportunity to try a 2-bottom plow with either of my compact tractors, and would not have wanted to try a 16" plow either. I had a 14" middle buster and just a 12" turning plow.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Kubota RTV500 (A47384)
2009 Ford F-550 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2009 Ford F-550...
2021 John Deere 8R 250 (A50123)
2021 John Deere 8R...
Countyline Single Row Plow (A50123)
Countyline Single...
