2 Acres half Woods and Lawn Is this B2320 for me?
   / 2 Acres half Woods and Lawn Is this B2320 for me?
That Deere price seems high to me, but they may be charging a lot more for the mower than I expect.
If ground clearance is important, I question the desire for a SCUT. Based on previous discussion, maybe you should have a dedicated mower and a CUT. That's what I do, and many other folks here too. It's hard to get a machine that mows well and also is capable in the woods and for heavy work.
R4 tires are intended for worksite/construction use and for supporting heavy loads. The don't have the traction of an R1 or the turf-friendliness of turfs. So they aren't really a compromise between the two factors you cited at all -- they are just worse at both things. My R4 tires tear up my lawn considerably unless it's bone dry. I'd never want to mow with them. I chose them because they were the best option for loader work and general construction work.
That's good to know on the R4 tires. I could swear I read a threat where a fellow said they were fine on his lawn. As for 2 machines, I was really hoping to get down to 1. I'm afraid I couldn't justify the expense for a CUT dedicated only to "tractor" work. Perhaps I am trying to convince myself I can justify a purchase when a rental would suffice? Food for thought.
I have received 2 quotes now via email that are within $100 of each other for the JD. When I replied to one dealer asking if the price was firm or if they would work with me on the sale I received the following reply just minutes ago. Seemed pretty abrupt to me:
"Thanks for your update and where you are at with your
purchase process.I agree with most of what you have said and
yes the proof is in the pudding so come on over and spend
sometime on our product and you will see the difference.And
by the way im the boss and i gave a awesome deal to start
with.I dont like to play around with prices.I will be
staurday i look forward to meeting you and going over our
product."
   / 2 Acres half Woods and Lawn Is this B2320 for me? #42
It sounds like you're getting close. As with any of the brands there are differences, what helped me decide was knowing what I needed the machine to do and what machine fit best. Some have better loader control valves, some have that cooling fan issue. However all make great products. However realize machines have their limits and all will be good. For what it's worth, some brands liquid cool the hydros differently than it being underneath the tractor cooled by a fan that has been a problem for some. It all comes down to what you need from tractor and the work it will produce. Donnie
Brasco,
Since you are in my neck of the woods, can you tell me your experience with your particular type of tire? Do you mow? How does it treat your lawn. Also, since you know the terrain in the woods (generally), do you think a SCUT would get by? Thank you.
   / 2 Acres half Woods and Lawn Is this B2320 for me? #44
I have r4's on mine, however the ground in NH is too wet and soft for any tire to not damage a lawn. As of yet I haven't mowed with mine, first spring with the machine. All machines have their limits and just be aware of them. I think for the size property and primarily what you'll be doing you'll be just fine. SCUTs aren't really woods machines however if you'll be maintaining or making small trails you'll be ok. Just make sure the ground is dry so you don't sink in mud, ask me how I know lol. If you go with the bx I'd recommend the skid plates from bxpanded. With that said my SCUT has done all I needed it to do with ease. Move snow, dirt, horse poo lol. My Mahindra Max cools the hydro by piping the cooling coil up by the radiator so I dont have a fan in that spot to worry about burying and breaking. It doesn't have refined loader controls like the bx, not a deal breaker for me. It has a pin on bucket, not a ssqa, however wasn't a deal breaker for me. It does have a quick park fel which is nice so I can remove it when I do mow. The FEL also comes with a grill guard not an option, I'd also recommend that. The rear end is steel and no aluminum like the Deere. Like I said find what fits and works for You! I think size wise for your land a primary uses a SCUT is a better fit, but that's only my opinion and is worth what you paid for it. Donnie
   / 2 Acres half Woods and Lawn Is this B2320 for me? #45
product."
I have read some crazy things about tires on TBN (it can start debates). In fact one person claimed the R4 was a hybrid between R1 and turf, to be easier on the lawn. Truth is, the R4 evolved as an industrial/construction tire, focused on supporting loads on harder surfaces and being more puncture resistant. Turf never factored into it. You'll find them on backhoes and other construction equipment as well as tractors. It makes a great tire for general use and when a lot of loader work is being done, or when operating in construction/industrial settings, but really isn't good at much else. R1 is the king of traction in soil or mud, hence the reason you see them on farm tractors most often. Turfs are the easiest on lawns and landscaped surfaces, so you'll see them on mowers and at places like golf courses.
Yes the R4 is easier on turf than an R1, but that's like saying a bulldozer is easier on the turf than a military tank. Both tires are going to do damage if the ground is soft, especially in turns, and especially with 4WD engaged. Turf tires are significantly better on turf than either R1 or R4. Significantly.
What you really need to do is figure out the main purpose of the tractor, then pick tires accordingly and realize they will be a compromise at everything else. That will happen no matter what tire type you pick -- no tire is good at everything. So figure out the main purpose of the tractor and the most important feature your tires should have, and the choice will become apparent.
I have a local Deere dealer that I have bought from in the past, and they are good people, but they generally have a take it or leave it attitude on larger tractors (on riding mowers they are more willing to deal). I remember back in 2011 getting a price on the 1026R (precursor to the 1025R), and then heading over to the Kubota dealer and getting a better price on a larger B model. The B happened to be built nicer too, in my opinion, with metal hood and fenders compared to plastic on the Deere, a proper electric fuel gauge in the instrument panel (Deere's gauge is float based, on the fender), and a host of other small details. it was a no brainer at that point and I bought the B, which served me well.
   / 2 Acres half Woods and Lawn Is this B2320 for me? #46
Well said s219
   / 2 Acres half Woods and Lawn Is this B2320 for me? #47
product."
Avery, with all due respect, the bid response you got from the one dealer was perfectly handled on his part. Getting a bid with details us a fine thing for email . . but you don't try to negotiate them down by enail . . thats something you do face to face. Or at the least by telephone. Dealers get tired of people trying to do nickel and dime negotiating by email because it always means you're trying to play one off the other. When you use the words "can you work with me" they shoukd always be vocal imo - preferably in oerson and honestly stated. It doesn't mean a committment to buy but it does mean a committment to deal with people directly.
Thank you for the advice Sir.
For the record, this is what I sent to the dealer:
Thank you for the prompt reply. I am in the early
stages of my research at this point and have looked at
several models. I have narrowed my decision down to
the 1025r or the Kubota 2370-1 - both with the 60" MMM and
FEL. I have your quote and one from a Kubota dealer
and plan to visit a competitor for both brands so I will
have 2 quotes each.
I have driven a Kubota and I liked it. I have
not had a chance to drive a JD but I intend
to and I think I will get used to either platform
with a little practice.
I find value in good engineering so I expect the
JD to cost a little more but the the proof is in the
pudding and without testing your machine, I am
in no position determine its value to
ME.
That said, does your company work with the
customer or should I consider the quote written in
stone? I would like to visit this weekend and take a
ride.
Thank you very much for your time and I look forward to
meeting you.
V/R
   / 2 Acres half Woods and Lawn Is this B2320 for me? #50
Not a good negotiating technique in my opinion.
You can use all those words and how you are going to.make your decision, it does not matter.
Just show up tell him you want to test drive, and then get his best price.
Do that at each dealer.
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2014 Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
2014 Lay-Mor...
2015 John Deere 35G Mini Excavator (A49461)
2015 John Deere...
