1st use of 2320
   / 1st use of 2320 #1
Jksnvly
Endless Mntns of Pa.
After sitting all winter long, I finally had the opportunity to use my new 2320. I took delivery of 500 3' Norways Spruce to plant at the 'mntn' house. Using a Speeco post hole digger made it fun. I'm amazed at the power these units generate, at not much more than an idle.
   / 1st use of 2320 #2
thats the setup i needed when i planted some one gallon trees a few weeks back..
I used a set of post hole diggers (manual type) that made digging the holes much easier than using a shovel...
nice looking set up
Brian
   / 1st use of 2320 #3
Man, does that make me want to go out and get a few more implements!
   / 1st use of 2320 #4
Thats a really nice looking set up.
i wonder if a post hole digger would work with an I-Match
Nice tractor. I like Green....:)
   / 1st use of 2320 #5
Nice lookin' setup! And those pretty rolling hills ain't hard on the eyes either!!
Chris -- you might figure out a way to burn some steel together and make the PHD fit the IMatch.... but normally, it won't work.
AKfisk
   / 1st use of 2320 #6
Post hole diggers will not work with any iMatch type quick hitch.
   / 1st use of 2320 #7
AKfisk
do you mean just that one. or no post hole digger. like the JD or frontier
will not work with I-Match eather...:confused:
   / 1st use of 2320 #8
None that I know of will work with an Imatch. You have to take off the top link on all that I have seen.
   / 1st use of 2320 #9
None that I have ever seen. As aesanders said, you have to remove the top link to hookup post hole digger.
   / 1st use of 2320 #10
jksnvly, I printed your picture of the 2320 so I can see what my machine will look like when it gets here. Hope you don't mind. 11 more days and counting!
2019 Ford Fiesta SE Hatchback (A55853)
2019 Ford Fiesta...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
JNC 1224 Jump Box with Charger (A54865)
JNC 1224 Jump Box...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
202474 (A54757)
202474 (A54757)
Massey Ferguson 135 Tractor (RUNS) (A50775)
Massey Ferguson...
