1st Problem
/ 1st Problem #1
Triker
Cleveland, Tennessee
PT 425
Well, I have 10 hours on my 425 and it is now setting in the middle of my woods and will not start. Was running along fine and it just died..........After some checking around, I found a blown 30 amp fuse near the starter solenoid. Replaced the fuse and as soon as I turned the key on, it blew the fuse again. Anyone ever have that type of problem before? or any suggestions on what to do next?
Thanks
/ 1st Problem
Thanks
/ 1st Problem #3
here is a couple threads where folks report similar problems.
PT wont start
PT wont start after 8 hours
Common theme: fuse blew, replacing didn't fix it, problem turned out to be the red wire jarring itself loose from the starter solenoid.
/ 1st Problem #4
PT wont start
/ 1st Problem #5
Look under the front panel that covers the steering console. This is a flat plate with 4 bolts. Look for a wire that has come loose and is shorting to ground. Also trace a wire back to the fuel shutoff solenoid on the engine. If this has a connection to ground this will be your problem. These are not things that I have found, just suggestions.
Replace the fuse with a 12 volt light bulb. It will turn on when you turn the key. Wiggle wires and see if it gets dimmer. This may help you isolate the problem without going through a lot of fuses.
I wish I could be more specific.
Bob Rip
/ 1st Problem #6
Bob Rip
/ 1st Problem
Thanks Tim, will check that wire tomorrow and the links were helpful also. /forums/images/graemlins/smile.gif
Bob, will check your suggestions tomorrow also.
/ 1st Problem
/ 1st Problem
After troubleshooting with Terry this morning, it seems that I have a bad thermo coupler on the fan. Terry is putting one in the mail. Thanks for the help.
/ 1st Problem
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
