1998 kioti 3054 adding loader
/ 1998 kioti 3054 adding loader #1
reelnative
sw florida
ford 3500,cat 416 w extenda hoe,bobcat 853,john deere110,kioti 3054, taskmaster 426e
this is a first to me so im going to need some help, I have a westendoft ta25 loader to install on the kioti 3054 but dont know how much flo or psi this tractor has, also I dont know if this loader is too big for the tractor eather, also what type of control will I need as the laoder doesnt come with one, the loader has 2.5in dia rams, thanks for any help
thanks JJ could you tell me what open center is I dont have a clue, and does this tractor put out 7gpm or is that what im gonna need thanks
/ 1998 kioti 3054 adding loader #4
That means that there is no pressure in the system until a valve is activated, although the pump is running. Also, all the valves are in series.
The specs say 7 GPM valve flow, which is the volume at max pump speed. The volume of fluid will determine the cyl speed, or the speed of a hyd motor.
Thanks again JJ you are a welth on knowledge, would you happen to know what the psi its running and do you think 7gpm is enough to run a loader or should I say power the loader good enough Thanks again
/ 1998 kioti 3054 adding loader #6
Total pump flow is 10 GPM. so about 3 would go to the power steering. Psi should be around 2300 to 2500. Check the manual for your specs.
UNUSED JCT QUADRUPLE TINE BALE SPEAR (A65055)
UNUSED JCT...
2020 CATERPILLAR 926M WHEEL LOADER (A65053)
2020 CATERPILLAR...
KL480 Ventrac tiller
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
UNUSED RAYTREE RTSG30 HYD TRANSVERSE STUMP GRINDER (A65055)
UNUSED RAYTREE...
213088 (A64276)
213088 (A64276)
