1997 F150 Electrical Issue
   / 1997 F150 Electrical Issue #1
deerefan
louisiana
1952 8N, 2005 JD 5103
This is odd, wondering if any of you have experienced this. With the cruise control on, when I put my blinker on to change lanes, the cruise control turns off. Any ideas?
   / 1997 F150 Electrical Issue #2
Been a while since I worked on one. I seem to remember a tsb or a recall on the cruise. A short I think. Sounds like what you are experiencing anyway. Have you looked on any f150 boards? Good luck!
I recall that tab. I had that addressed, the short caused some fires if I recall.
   / 1997 F150 Electrical Issue #4
Sounds like a bad ground (possibly in the taillight causing power to backfeed into the brake light circuit and making the cruise thing that you just hit the brakes).
Aaron Z
   / 1997 F150 Electrical Issue #5
Check the bulb on your 3rd brake light on back of the cab.
   / 1997 F150 Electrical Issue #6
My guess is you have a short between your brake lights and your turn signal lights. My first thought is the trailer plug.
As you know when you apply brakes your cruise control disengages. This short is making this happen.
Chris
Just did. Look at what I found. I took the bulbs out and will see if it helps. Both bed light sockets are melted. Not sure why.
   / 1997 F150 Electrical Issue #8
yummy!
   / 1997 F150 Electrical Issue #9
Good thing you bought that Tundra:laughing:
Yes and no. We traded 2 vehicles in for the Tundra, meaning the F150 is being driven more. It has a new engine but needs a few more items such as a dash and paint. Not a bad truck, just old (1997). I will be buying a newer vehicle with cash in the next yeat. For now, its the Ford.
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2019 Toyota Corolla Sedan (A51694)
2019 Toyota...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2013 Ford F-150 4x4 Pickup Truck (A51692)
2013 Ford F-150...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
