1996 John Deere 425 transaxle leak
   / 1996 John Deere 425 transaxle leak
Ok I have ran the tractor with the tires off and jacked up. My question is I didn't want to go buy that expensive John deere oil for my transaxle so I put 5w-30 synthetic in it for my test. Do yoy think that will hurt it??
   / 1996 John Deere 425 transaxle leak #12
It's your dime...
but I wouldn't do that. I'd spend the $23 per gallon and get the Hy Gard low vis.
   / 1996 John Deere 425 transaxle leak #13
Well took your advice and blew all the crap out of there that I could reach with air. Lo and behold I looked down on the shaft for the parking brake and there was a seal that had popped out of the case. I took a very long and skinny pry bar and did my best to push it back in. I will rig up my gas tank tomorrow and run the tractor and see if it pops out again or leaks. I hope this fixes it? Thanks for your help I will let you know tomorrow how things go.
Thanks weeder
You could have cleaned out the area with some brake cleaner and blew it dry, then put a few drops of Loc-Tite on it to help keep it in place.
Well, no leaks so far, I will drain out the fluid and change out the filter and replace it with the Hy Gard oil. If the seal comes out again, I will replace it.
   / 1996 John Deere 425 transaxle leak #15
Have you checked that the vent is not blocked as suggested. You do not want pressure to build in there, it could pop out a seal.
Yes, I have, I cleaned all around it took the rubber vent top off and checked it out all's well there.
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
LMC G500-500A LOT NUMBER 233 (A53084)
LMC G500-500A LOT...
2005 International 4300 Truck, VIN # 1HTMMAAL75H100984 (A51572)
2005 International...
2018 New Holland T8.350 MFWD Tractor (A53342)
2018 New Holland...
