1996 John Deere 425 transaxle leak
   / 1996 John Deere 425 transaxle leak #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Hello everyone, I have noticed that most of my oil in my transaxle has leaked out. I looked on both sides and it seems to be pretty dry. It looks like it is mostly wet underneath? Wonder where this is coming from. Any ideas????
Thks weeder
   / 1996 John Deere 425 transaxle leak #2
I fixed on a couple of years ago where a seal on the left side of the transaxle had worked out. I do not remember exactly what the shaft was for. I only had to lower the transaxle to gain access to this seal. I found it by carefully cleaning all the grass and accumulated crud from the linkage and brackets using air hose gently picking stuff out with small screw driver.
I would suggest cleaning everything off, topping off the fluid and then look for leaks with tires removed sitting on Jack stands so you can see the transaxle housing easier
Thanks oldnslo , I have cleaned it off as much as I can and yes it does look like it is coming out of the left side someplace. I will probably take the transaxle out and clean it better and re \look the situation over better! Yes an air hose or power washer will do the trick!!!
Thks weeder
Well took your advice and blew all the crap out of there that I could reach with air. Lo and behold I looked down on the shaft for the parking brake and there was a seal that had popped out of the case. I took a very long and skinny pry bar and did my best to push it back in. I will rig up my gas tank tomorrow and run the tractor and see if it pops out again or leaks. I hope this fixes it? Thanks for your help I will let you know tomorrow how things go.
Thanks weeder
   / 1996 John Deere 425 transaxle leak #5
On the one I fixed the old seal wouldn’t stay in the bore so installed new seal with a film of permatex on the OD. To best of my knowledge still going strong.
may want to double check to make sure the transaxle vent is clean. I wish could remember where it was located darn senioritis:)
   / 1996 John Deere 425 transaxle leak #6
Glad you found the loose seal.
Can you post up a pic or two of that seal?
Schematic from the service tech manual.. brake linkage
I would love to take a pic but I can't get my ph camera down in that position to do so, sorry. I'm going to run the tractor for a bit and see if it stays in place. If it doesn't I will have to pull the transaxle completely out to correctly replace the seal.
   / 1996 John Deere 425 transaxle leak #8
Beenthere
I think it was diff lock shaft seal going into side of transaxle case but could not find anything on Deere parts breakdown. Recall had same problem when fixing the unit. It is buried behind linkage between frame rail transaxle
   / 1996 John Deere 425 transaxle leak #9
That diff lock shaft seal is what I was thinking too.
part # M806040
Yes that is the seal and the part number if I have to replace it in the future.
Thanks beenthere
2013 RAM 4500 (A50323)
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
3 1/2 FT DISC HARROW (A51247)
3 1/2 FT DISC...
