1994 John Deere 320 wont start
/ 1994 John Deere 320 wont start #1
moresnow
JD 320; Hydra lift, 48" deck
Put a brand new battery in and tractor started on first try. However after turning off and trying again there is no power no lights or even dash. Help?
/ 1994 John Deere 320 wont start #2
The first place I'd start is removing, cleaning, and reattaching the battery cables. Likely not a problem if you just put in a new battery.
Look for something not set right, like the PTO switch on.
Double check that the battery is good. Has been known that a new battery can have a dead cell, or not be charged enough in the beginning.
Lastly, if still not finding the problem, start tracing the 12v supply to see that it is getting from the battery to the solenoid, and that the solenoid is getting 12v from the ignition switch.
The dash oil lights etc don't come on like they would with the pto switch
I did here a high pitched frequency buzzing sound during second try. Fuses?
It was corrosion at the cable to connector to the terminal. Cleaned everything and it worked out. V
