Tires 1993 Ford 1920 rear rims
   / 1993 Ford 1920 rear rims #1
Btown
MA
Ford 1920
I need new rear rims on my 1993 Ford 1920, I know you cannot find the original size rims. So the only ones you can find are 12”-24” six loops. I see some bolt center to center dimensions 20” and 20.25”. When I measure mine it is 20”’s center to center. Will rims like this work. Thanks.
   / 1993 Ford 1920 rear rims #2
Hope you get an answer cuz I have the same issue!
   / 1993 Ford 1920 rear rims #3
1920 is not among the listed compatible tractors for these rims, unfortunately. You could ask the eBay seller…
   / 1993 Ford 1920 rear rims #4
20 series and before were metric, so no they will not. I may have a set for rear rims. I will check tomorrow.
Here is what I bought. They fit perfectly, just had to buy new bolts and nuts.
   / 1993 Ford 1920 rear rims #6
Did you flip over center plate to get correct spacing?
[emoji[emoji6]]" data-quote="PAW" data-source="post: 0" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
No. I didn’t flip the center plate. If I flipped it, it would make the width of the rear tires narrower. I have the rears set to the second widest width.
70pc. 12ft. x 3ft. White Metal Roof/ Wall Panels (A53424)
70pc. 12ft. x 3ft...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND69FDGH1752 (A54865)
2015 Freightliner...
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
New/Unused CFG Industrial YSRT14 Min Skid Steer (A54865)
New/Unused CFG...
2023 DOUBLE DRUM ROLLER (A55745)
2023 DOUBLE DRUM...
