Tires 1993 Ford 1920 rear rims
   / 1993 Ford 1920 rear rims #1
Btown
MA
Ford 1920
I need new rear rims on my 1993 Ford 1920, I know you cannot find the original size rims. So the only ones you can find are 12”-24” six loops. I see some bolt center to center dimensions 20” and 20.25”. When I measure mine it is 20”’s center to center. Will rims like this work. Thanks.
   / 1993 Ford 1920 rear rims #2
Hope you get an answer cuz I have the same issue!
   / 1993 Ford 1920 rear rims #3
1920 is not among the listed compatible tractors for these rims, unfortunately. You could ask the eBay seller…
   / 1993 Ford 1920 rear rims #4
20 series and before were metric, so no they will not. I may have a set for rear rims. I will check tomorrow.
Here is what I bought. They fit perfectly, just had to buy new bolts and nuts.
   / 1993 Ford 1920 rear rims #6
Did you flip over center plate to get correct spacing?
[emoji[emoji6]]" data-quote="PAW" data-source="post: 0" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
No. I didn’t flip the center plate. If I flipped it, it would make the width of the rear tires narrower. I have the rears set to the second widest width.
1999 VaXcavator VT500D Towable Vacuum Trailer (A55851)
1999 VaXcavator...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
Skid steer auger plate (A50322)
Skid steer auger...
