1993 FORD 1520 POWER BEYOND
/ 1993 FORD 1520 POWER BEYOND #1
Power Beyond
1993 Ford 1520
What is power beyond on my tractor? How can it be used? I would like to add a 3rd hydraulic function- can it be used for that? If so, how would I be able to control the hyd. fxn.?
/ 1993 FORD 1520 POWER BEYOND #2
Power beyond would come from the diverter block on the right side. Square block looking thing with three steel lines attached, one coming directly from the hydraulic pump. You would tap in there by removing the plugs and adding fittings.
What "third function" are you considering? A spool valve or solenoid type?
Spool valve
