1989 Ford 3910 Hydraulic problems
   / 1989 Ford 3910 Hydraulic problems #1
Greenpaddy
Ireland
Ford 3910 1989
Hi All,
Love the site so had to join. I bought a 1989 Ford 3910....a beauty. My problem is the 3 point lift. it lifts up ok with the transport box on...but after about 2 minute it drops of its own accord. Lever stays in position ....so i have to get back in the cab and push down the lever and up again. checked the fluid and alls ok draft control lever is down and the setting under the seat is in right position. I just have it a month and im afraid i may have bought a good looking "lemon". what can I try or is the pump knackered ?
   / 1989 Ford 3910 Hydraulic problems #2
Pump will not cause 3 pt to lower once 3 pt is raised. Problem is either a faulty control valve or leaking rockshaft piston seal. Seeing that your tractor has a cab it will be a challenge to repair 3 pt.
Thanks Jim ! your so good to come back so quick. I will do some googling to see whats involved and what kind of €€€ are involved.
Kind Regards
By the way Jim .......do you know any good sites with schematics or where the valves are ???
   / 1989 Ford 3910 Hydraulic problems #6
2012 Nissan NV2500HD Cargo Van (A51692)
2012 Nissan...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53472)
2006 Magnolia Dry...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
